CompX Regulator Locks
Has anyone here setup the CompX Regulator Locks and would possibly be willing to share or give me some advice in the setup?  We have a job coming up and they are requiring these locks.
In a test job I have the lookup table for these setup for vertical and horizontal.  The issue I am running into is that there are 4 different orientations.  For Upper and Tall Cabinets the single vertical style works with the keypad above the lock.  But on a base cabinet it should be rotated with the lock above the keypad.  That is fine buts its a different part number and I want to pull the correct lock.
So adding a 180* rotation to the vertical isn't an option.  It needs to pull a different lock.  My thought is to possibly create a "Vertical Up / Vertical Down" code.  But I am not really sure where to do this since I want the 2D elevation to adjust as well but those are controlled in the lookup table.
