Default MicrovellumExport.sdf FileName is a pain
With the update allowing us to rename our .sdf file names on export, the default filename has also been changed to MicrovellumExport.sdf instead of MicrovellumFactory.sdf
This means that if I forget to change this back to MicrovellumFactory.sdf then whoever I share the export to cannot import it if their on an older build.
This can be remedied by changing the filename back manually, but most people don't know that, and if I don't remember to think of that as the issue, then we end up going in circles trying to troubleshoot why they aren't able to import what I'm sending.
Can we please just change the default back to what it has been for the entire history of MV to avoid this?
