Hanger Notch Isn't Including FE Scribe Amount
Update Hanger Notch Depth for Upper Cabinets in Microvellum Foundation Library
  • This pull request addresses an issue identified in the Microvellum Foundation Library version 24.1127 regarding the hanger notch depth for upper cabinets.
  • The problem arises when two upper cabinets of differing heights are placed next to each other, mainly when one is shorter to accommodate a refrigerator.
  • The hanger notch on the finished end of the taller cabinet does not account for the scribe amount, leading to the hanging cleat not being allowed to pass through the back of both upper cabinets continuously.
Assumptions
  • The current scribe amount is set to 3 inches for testing purposes, though this value may not reflect realistic scenarios.
  • The hanger notch depth must be manually adjusted to include the scribe amount, ensuring the hanging cleat runs continuously through both cabinets.
  • Suggested fix - Verify that the hanger notch depth is correctly adjusted to incorporate the scribe amount.
Link to Video
https://loom.com/share/0d02330a9dad4a90947446978fe1996c?src=composer
