Look Up Tables
I have an issue with Lookup Tables and Hardware.   We are adding different shelf clips to our hardware list so they show up on the hardware processing lists.  I added a Hafele pin to the hardware tab in the material files and went to the look up table for shelf pins and added a row for the Hafele pin with the clip gap.  When it is assigned, it will find the name in the look up table and return that but will not find the clip gap which drives all the shelf formulas.  Is there something I'm missing here?
