Map Material to Processing Station
Has anyone ever seen the benefit of 'mapping' materials to a specific CNC machine? That would let you set up each material so that each part would be populated to the processing center with a combination of stations already assigned. Instead of a manual process of loading one material, setting the stations, processing, clearing the stations, loading the next material, setting the stations, etc, the parts from these materials would come in pre-assigned.
