I have a open base cabinet that I inserted a pigeon hole sub assembly. The material was spec'd at .75 melamine. The material we got came in at .78 so I created a sheet size for that and changed the material in the spreadsheet. When I did that and redrew the product it didn't update the machining and sub-assembly machining to accommodate the thicker material and I had to go back and manually change all the dados and lap joints and re-align everything. my question is why it didn't update all the machining etc. for the new material?
