More available colors in the color column
Currently you can color your prompts with the color column, but the available colors are limited to the first 9. I would like to be able to use the full AutoCAD color catalog (Either the Index Color 1 - 255, or the RGB equivalent Color Books 1-255,1-255,1-255) when coloring prompts in order to help further distinguish different prompts. This would also be helpful for determining parent and child prompts so that for example the parent prompt could be a bright green and the child prompts could be a dark green.
