Multiple Offset Route Priorities
When using the fifth cell of the PLINE token you can offset the vectors mapped out in the first cell and you can do this multiple times when using the "{X:Y:/|X;Y;Rotation}" format, but is there a away to set individual priorities for these offset routes? How does the software decide which route to cut first? Does it go in the sequence  they are written in the token? Can you bracket the options in cell four and set options for each offset route (similar to the PLINEFROMHOLE token)?
I looked but cant find any help on the Knowledge base side for PLINE tokens.
I appreciate if anyone can point me to the pline help documents if there are any dealing with this, or sharing any experience you have. Thanks
