I was very happy to get the 2020 update with Report Groups. It was the first thing I attempted to setup, which was very easy. However, while working through the setup and actually printing reports I would suggest the following:
- Have an option to select a particular printer for each report. Some of our reports require to be printed on a label printer. At this point I need to exclude from the report grouping.
- In Work Order Creation window, provide a pull down of selected Report Groups available. We have a different set of reports to print for the different type of projects we produce.
- Have better control of the printing sort order. Currently the only option is to sort by Name or Processing Center. I would require neither of those options but rather specifically what report to print in a certain order.
- Ability to ad a formula to determine if a report is required to print. For example, I have a report that list all of our drawer box parts to be pulled from inventory or created from scratch. If I run a project that does not have any drawer boxes I do not need this report. I have several reports I would use this feature.
I think this is a great feature added to Tool Box. I had I nice taste of it I just want more.
