Reference Updates
Greetings,
I have the Toolfile Column Heading PDF from several years ago. I've noticed the IPP toolfiles Tools tab will post some values in Cols. BA & BC which aren't defined in the old Column Heading document. These entries duplicate some values in the user interface for Vbores & 900 tools. Is there an updated version of this reference?
Also, my Token Parameters XLSX file is from 1/9/17. I'd like the updated version of that doc as well if you've got one. Searching for these docs gets no focused result. I'm attaching the versions I have on hand and a couple TLFX files with the BA and BC columns in use.
Thanks,  Rich
