Shadow Line Backing Rails in drawers
Hello to the Library Development team.
It would be great if we could control whether the shadow line backing rail is in between sides or overlaying sides from the Global file or the shadow line table in the D! workbook.
Our construction method requires that a Vertical rail is provided behind the Solid Rail material, with machining, for fixing upon install.
At the moment there is a prompt in the Shadow Line subassembly "Backing Rail Inbetween Sides". This prompt only activates when you use the "L Shaped Solid Rail" shadow line type which is great but if the "Backing Rail Inbetween Sides" was looking to a prompt in the globals or from an option in the Shadow Line Table.
The Vertical also needs to be the same height as the shadow line when not using a "Drawer Stretcher" between drawers.
