Shelf Line Bore Holes
Hello Everyone,
I am having a problem with my line bore holes, They aren't there. The last project I just did worked fine, Started a new project, same spec group, same everything and no shelf pin holes. I have copied the spec group from the last job with no success. I have checked all the material and its correct, I haven't changed anything for the shelf pins holes(that I know of). If I go back into the last project I just did everything works fine. Any help would be greatly appreciated, as I'm still learning this is only my 2nd month using this software so please be as  descriptive as you can.
Thanks
Travis
