Hi .
See attached. The Return filler is doing a pocket instead of a route. The formula has no option for a 'Route5'. Am I missing something? I reckon it should be the following formula...or similar.
Machine Token
=IF(L_Shape_Filler=1,"PLINE5","")
Parameter 1
=CONCATENATE(Width,";",Depth+G!Router_Lead,";",Thickness_Filler+G!Router_Clearance,"|",Width,";",Width,";",Thickness_Filler+G!Router_Clearance,"|",Height+G!Router_Lead,";",Width,";",Thickness_Filler+G!Router_Clearance)
