I am having a problem finding the solution to this and I am hoping it's an easy fix that I am overlooking. My company doesn't use integral toe kicks and chooses to use ladder style base instead. When I draw a 2D elevation, It draws everything it is supposed to and everything it's set up to draw. However, it adds a vertical line to a finished end where the integral toe kick would be... but there isn't an integral toe kick. How do I shut this vertical line off? Where is the prompt or setting for this? I am using Toolbox 2023, component library V50.7
