If the visual style setting is 2D Wireframe, the visual style changes to 3D Wireframe for the duration of the command.
When the 3D Rotate gizmo is displayed, the 3D Rotate Gizmo shortcut menu offers options for aligning, moving, or changing to another gizmo.
Select Objects
Specifies the objects that you want to rotate.
Base Point
Sets the center point of the rotation.
Pick a Rotation Axis
On the 3D Scale gizmo, specifies the axis of rotation. Move the mouse until the axis path you want to select turns yellow, then click to select it.
Specify Angle Start Point or Type an Angle
Sets the relative start point of the rotation. You can also enter an angle value.
Specify Angle End Point
Rotates the object about the specified axis. Click to end the rotation.
Powered by AutoCAD®
