About Constructing Meshes from other Objects
Create meshes by filling the space between other objects such as lines and arcs.
You can use a variety of methods to create several types of mesh objects whose edges are defined by other objects. Mesh types include ruled, tabulated, revolved, and edge-defined meshes. The MESHTYPE system variable controls whether the new objects are valid mesh objects, or whether they are created using legacy polyface or polygon geometry.
You can control how the mesh is displayed by changing the visual style (VISUALSTYLES).
Create a Ruled Mesh
RULESURF creates a mesh that represents the ruled surface between two lines or curves.
There are several methods for creating ruled meshes. For example, you can use two objects to define the edges of the ruled mesh: lines, points, arcs, circles, ellipses, elliptical arcs, 2D polylines, 3D polylines, or splines.
Both objects that are used as the "rails" of a ruled mesh must be either open or closed. You can pair a point object with either an open or a closed object.
You can specify any two points on closed curves to complete the operation.
For open curves, construction of the ruled mesh is based on the locations of the specified points on the curves.
Create a Tabulated Mesh
TABSURF creates a mesh that represents a general tabulated surface. The surface is defined by the extrusion of a line or curve (called a path curve) in a specified direction and distance (called a direction vector or path).
The path curve can be a line, arc, circle, ellipse, elliptical arc, 2D polyline, 3D polyline, or spline. The direction vector can be based on a line or an open 2D or 3D polyline.
This method creates the mesh as a series of parallel polygons running along a specified path. The original object and the direction vector must already be drawn, as shown in the following illustrations.
Create a Revolved Mesh
REVSURF creates a mesh that approximates a surface of revolution by rotating a profile about a specified axis. A profile can consist of lines, circles, arcs, ellipses, elliptical arcs, polylines, splines, closed polylines, polygons, closed splines, and donuts.
This method is useful for mesh forms with rotational symmetry.
Create an Edge-Defined Mesh
EDGESURF creates a mesh approximating a Coons surface patch mesh from four adjoining edges. A Coons surface patch mesh is a bicubic surface that is interpolated between four adjoining edges (which can be general space curves).
The mesh in the following illustration was derived from four objects called  edges. Edges can be arcs, lines, polylines, splines, or elliptical arcs that form a closed loop and share endpoints. A Coons patch is a bicubic surface (one curve in the  M direction and another in the  direction) interpolated between the four edges.
Powered by  AutoCAD ®
