About Page Setups and the Sheet Creation Template
This brief article regards a specific aspect of working with Sheet Sets, Page Setups, and the Sheet Creation Template. For more information regarding the functionalities found in the Sheet Set Manager, see Overview: Sheet Set Manager – AutoCAD and About Sheet Sets in AutoCAD.
For information regarding Sheet Sets in a Networked Environment, see Using Sheet Sets in a Networked Environment.
For information regarding Publishing, Transmitting, or Archiving Sheet Sets, see About Publishing, Transmitting, and Archiving Sheet Sets
Page setups provide the settings that are used for publishing and plotting. When you create a sheet set, you specify a drawing template (DWT) file that contains one or more page setups for all new sheets. This DWT file is called the sheet creation template.
Another DWT file, called the page setup overrides file, contains page setups that can be specified to override the page setups in each sheet. You specify the page setup overrides file in the Sheet Set Properties dialog box.
When you publish a sheet set, you can use the page setups defined in each drawing file, you can use the page setup overrides for all drawing files, or you can publish to a DWF or DWFx file.
With page setup overrides, you can use the PUBLISHCOLLATE system variable to control whether plotting a sheet set can be interrupted by other plot jobs or not.
Powered by AutoCAD®
