Basic 3D Commands
Basic 3D Commands
Basic 3D Commands
- EXTRUDE
– The EXTRUDE (EXT) command will allow you to create a 3D solid object from a
2D object.
- PRESSPULL
– The PRESSPULL (PRESS) command will allow you to create a 3D solid object from
a 2D object or an island (area enclosed by other objects). Although similar to
EXTRUDE, PRESSPULL will keep the original 2D objects instead of deleting them as
EXTRUDE will.
- UNION
– The UNION (UNI) command will allow you to “weld” two or more 3D solid objects
into one.
- SUBTRACT
– The SUBTRACT (SU) command will allow you to remove a 3D solid object from
another solid object.
- 3DMOVE
– The 3DMOVE (3M) command will let you move parts along a selected axis.
- 3DROTATE
– The 3DROTATE (3R) command will allow you to rotate parts around a select
axis.
- CHAMFER
– The CHAMFER (CHA) command, when working with 3D objects, will allow you to
create a diagonal cut along the edge of an object.
- FILLET
– The FILLET (F) command, when working with 3D objects, will allow you to
create a radius cut along the edge of an object.
- FLATSHOT
– The FLATSHOT (FL) command will create a 2D representation of 3D objects based
on the current view. For example, using a front view, FLATSHOT will create an
elevation view. Using an isometric view will create a “3-dimensional”
representation in 2D.
