Valid objects include lines, arcs, elliptical arcs, helixes, open polylines, and open splines.
Select First Object or Continuity
Selects a line or open curve near the end where the spline should start.
Second Object
Selects another line or open curve near the end where the spline should end.
Continuity
Tangent
Creates a degree 3 spline with tangency (G1) continuity to the selected objects at their endpoints.
Smooth
Creates a degree 5 spline with curvature (G2) continuity to the selected objects at their endpoints.
If you use the Smooth option, do not switch the display from control vertices to fit points. This action changes the spline to degree 3, which will change the shape of the spline.
Powered by AutoCAD®
