The Closet/Wardrobe Expansion Overview
About the Expansion
The Microvellum Closet/Wardrobe Expansion contains a wide collection of closet/wardrobe products, inserts, hardware, and customization options to complement the Foundation Library. This article will provide you with an overview of the Closet/Wardrobe Expansion and contains a listing of products, subassembly inserts, and options included.
Closet/Wardrobe Master Products
Master Closet
Description: This is a “Master” product capable of being saved back to the library numerous times in an unlimited number of different combinations.  This closet unit is equipped with one bay.
Main Options:
  1. Parametric Sizing Width/Height/Depth
  2. System 32 or regular hole patterns
  3. Overlay Tops & Bottoms can extend or reduce Left/Right
  4. Specify Back / No Back / Cleats
  5. Single or Double Partitions
  6. Face Options for each bay (No Door, Doors, Drawers, etc.)
  7. Access to All Construction Methods
  8. Access to Material Options
  9. Access to 2D Drawing Options
  10. Access to Hang Rail Hardware Options
Additional Info: Product has access to all 16+ Foundation Library Component Inserts and can be split into two openings by checking (ticking) the box on a center shelf (each with access to different component inserts). Can also be converted into a Hutch giving many different design options.
Master Corner Closet
Description: Single corner closet unit with only one bay. This is a “Master” product capable of being saved back to the Library numerous times in an unlimited number of different combinations.
Main Options:
  6. Access to All Construction Methods
  7. Access to Material Options
  8. Access to 2D Drawing Options
  9. Access to Hang Rail Hardware Options
Additional Info: Product has access to all Foundation Library Corner Component Inserts and can be split into two openings by checking (ticking) the box on a center shelf (each with access to different component inserts).
Master Straight Designer Closet
Description: Straight run of closet units up to ten (10) bays wide. This is a “Master” product capable of being saved back to the library numerous times in an unlimited number of different combinations.
Main Options:
  2. Opening Bay Calculator to specify and calculate opening sizes for each unit
  3. Control Individual Bay Heights & Depths
  4. System 32 or regular hole patterns
  5. Overlay Tops & Bottoms can extend or reduce Left/Right
  6. Specify Back / No Back / Cleats (individual or full)
  7. Single or Double Partitions
  8. Face Options for each bay (No Door, Doors, Drawers, etc.)
  9. Access to All Construction Methods
  10. Access to Material Options
  11. Access to 2D Drawing Options
  12. Access to Hang Rail Hardware Options
Additional Info: Each bay has access to all 16+ Foundation Library Component Inserts and can be split into two openings by checking (ticking) the box on a center shelf (each with access to different component inserts). Each bay can also be converted into a Hutch giving many different design options.
Master Single Carcase Designer Closet
Description: Straight run of closet units up to ten (10) bays wide within a single carcase This is a “Master” product capable of being saved back to the library numerous times in an unlimited number of different combinations.
Main Options:
  3. System 32 or regular hole patterns
  4. Overlay Tops & Bottoms can extend or reduce Left/Right
  5. Specify Back / No Back / Cleats (individual or full)
  6. Options for Full Bottom With Kick / Full Bottom / No Bottom
  7. Face Options for Sliding Door / Folding Doors / None
Master L Shape Designer Closet
Description: “L” shape run of closet units up to ten (10) bays wide with up to nine (9) return bays. This is a “Master” product capable of being saved back to the library numerous times in an unlimited number of different combinations.
Main Options:
  2. Two Opening Bay Calculators to specify and calculate opening sizes for each unit along the front and return
Additional Info: Each bay has access to all 16+ Foundation Library Component Inserts and can be split into two openings by checking (ticking) the box for a center shelf (each with access to different component inserts). Each bay can also be converted into a Hutch giving many different design options.
Master U Shape Designer Closet
Description: “U” shape run of closet units up to ten (10) bays wide with up to nine (9) return bays left/right. This is a “Master” product capable of being saved back to the library numerous times in an unlimited number of different combinations.
Main Options:
  2. Three Opening Bay Calculators to specify and calculate opening sizes for each unit along the front and returns
Closet/Wardrobe Master Doors & Frames
Closet Hinged Door Frame
Description:   Straight run of jamb openings with up to eight (8) doors wide. This is a “Master” product capable of being saved back to the library numerous times in different variations.
Main Options:
  1. Parametric Sizing Width/Height/Depth/Jamb Width
  2. Left/Right Fillers
  3. Options to specify single, double, or no posts between each door
  4. Striker Cleats (Separate Floor Plate)
  5. Door Options for each bay (Left/Right Swing, Overlay/Inset)
  6. Handle & Lock Options
  9. Access to All Door Types & Styles
  10. Access to 2D Drawing Options
Closet Aluminium Sliding Door Frame
Description:   2, 3, or 4 Sliding Doors with extruded Aluminium track and frame (Bottom, Head and Wall Jambs). This is a “Master” product capable of being saved back to the library numerous times in different variations.
Main Options:
  2. Left/Right Applied Ends
  3. Options to specify No Bottom / Track Rail / Full Bottom
  4. Options to specify No Top / Full Top
  5. Tick Box options for Left/Right Jamb, Bulkhead, Rear/Left/Right Top Cleat
  6. Profile Combo-Box Options for Style, Bottom Track, Head Track, Left Wall Jamb, Right Wall Jamb, Finish
Closet/Wardrobe Subassembly Inserts
Closet Carcase, Corner Closet Carcase
Description: Closet Carcase Subassembly is designed to be added into each closet product’s bay opening.
Main Options:
  2. Toe Kick Options
  3. System 32 Options
  4. Overlay Top & Bottom Options
  6. Cleat Options
Shoe Shelf
Description:   Shoe Shelf Subassembly Internal Insert designed to be added into any product’s square opening.
Main Options:
  2. Shelf Qty to specify number of shelves
  3. Shelf Height Calculator
  4. Shelf Setback variable to push shelves in from opening face
  5. Shelf Angle variable
  6. Continuous hole pattern or individual linebores per shelf
  7. Shelf Standards option
  8. Shelf edge options for Edgebanding or Lip Up / Lip Down
  9. Optional parametric shaped edge detail
  10. Shelf hole variables for locations & spacings
  11. Access to All Construction Methods
  12. Access to Material Options
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the parts are located.
Hafele Dress Code Pull-Out System
Description: Hafele Dress Code Pull-Out System Subassembly Internal Insert designed to be added into any product’s square opening.
Main Options:
  1. Parametric Sizing Width/Height/Depth*
  2. Pull Out Qty up to ten (10)
  3. Nine pre-loaded system types with a LookUpTable ready to accept more
  4. Pull Out Position variables
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the shelves can be located.
Hafele Pull-Out Frame System
Description: Hafele Pull-Out Frame System Subassembly Internal Insert designed to be added into any product’s square opening.
Main Options:
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the systems can be located.
*Since the Widths are fixed values depending on the selection type, a special prompt called “Required Inside Width” can assist the user to verify the appropriate width is maintained. If the Width is not correct, a custom Warning Message is included that will trigger a message.
Hettich Duo Lift System
Peka Shoe Pullout
Fold Down Hamper With Door
Strip Lighting Insert
Closet/Wardrobe Construction Options
Products in the Closet/Wardrobe Expansion have access to all Foundation Library Construction Methods including:
  1. Screw
  2. Dado
  3. Dado & Screw
  4. Cams
  5. Dado & Cam
  6. Dowel
  7. Dowel & Cam
  8. Dowel & Screws
  9. Invisible Fasteners
  10. Hardware Array
Closet/Wardrobe Product Options
Products in the Closet/Wardrobe Expansion have access to the following Foundation Library Options:
  1. Door & Drawer Front Options
  2. Adjustable and Fixed Shelf Settings
  3. Drawer Box Variables
  4. Adjustable Feet Options
  5. Hardware Options
  6. Material Options
  7. Inset and Overlay Options
System 32
An option for a 32mm Euro system style of line bore is included within products found in the Foundation Library Closet Expansion. This standardized system uses holes spaced in 32mm increments for mounting hinges, drawers, and all the necessary hardware needed to assemble a closet or cabinet.
When using System 32, several rules & variables need to be set up & followed. If any of the following items are not set up correctly, issues may occur within your closet products and components.
The line bore is the array of holes that come predrilled on each part. The following rules apply to all line bores:
  1. Holes are 5mm in diameter.
  2. Holes locate all hardware (horizontally and vertically).
  3. Holes are always 32mm apart center to center.
  4. Holes are always 9.5mm from center of hole to edge of part.
  5. Hole drilling determines part size.
  6. The centerline of the part lines up with the centers of the holes used.
  7. The Global variable “Front Shelf Hole to Edge” needs to be set to 37mm to match up with the hinge plate setback from the front edge.
  8. The Global variable “Cam Distance to Front Edge” needs to match the “Front Shelf Hole to Edge”.
  9. The Global variable “Cam Distance to Back Edge” needs to match the “Rear Shelf Hole to Edge”.
  10. The Global variable “Default Closet Toe Kick Height” needs to be in increments of 32mm.
  11. The Height of the closet is determined from the hole count and the hole spacing (32mm). Reference the prompt “Required Height” to match the Height of the product.
  12. The Height of drawer fronts are determined by the “Drawer Hole Count” prompts.
  13. The intended construction method to use is “Cams”.
    • Foundation Library Subassembly Inserts
      Foundation Library Subassembly Inserts This article will provide you with an overview of the Subassembly Inserts included within Microvellum's Foundation Library. Each subassembly has its own set of configurable options and can be inserted into a ...
    • The Range Hood - Add-on
      About the Library Add-on This is a “Master” Range Hood product capable of being used as is or saved back to the library numerous times in unlimited number of different combinations. This Library Add-on is compatible with the Foundation Library. This ...
    • The Staircase Expansion Overview
      About the Expansion The Microvellum Staircase Expansion contains a collection of staircase layouts to plug into the Foundation Library. This article will provide you with an overview of the Staircase Expansion and contains a listing of products, ...
    • Face Frame Expansion Overview
      Face Frame Expansion Overview The Microvellum Face Frame Expansion for the Foundation Library contains a broad collection of various Face Frame cabinet products intended to be used as a starting point for manufactures or create their own catalog. The ...
    • Material Pointers Guide
      Material Pointers A downloadable PDF of this article is attached to this page. This document is written to reflect the software as of Microvellum Foundation Library build 25.0418. Some sections in this article contain information in tabbed format. ...
    • Microvellum Remote Desktop (RDP) and RDS Compatibility
      Microvellum BSB and Microvellum AC support remote desktop connections to dedicated Windows computers, including physical workstations and persistent virtual desktops. However, Microvellum does not support multi-session environments, where multiple ...
    • Microvellum Foundation Library Release Notes | Build 26.1030
      The following release notes apply to Microvellum Foundation Library build 26.1030. Modifications The Nover Krome Premium Plus drawer system's Black finish option has been removed from the Hardware Library, as this system is only offered in White ...
    • Microvellum Foundation Library Release Notes | Build 26.0929
      The following release notes apply to Microvellum Foundation Library build 26.0929. Additions The Furnware AERO drawer system has been added to the library catalogue for the AU, NZ, and All region options. Machining and reporting have been developed ...
    • Microvellum Subassemblies Guide
      1. What is a Subassembly? Subassemblies are one of the most flexible parts of Microvellum, allowing you to reuse a component — a drawer box, a door, a hardware group — across many products without rebuilding it each time. That flexibility is derived ...
    • Microvellum Projects and Drawings Grid View
      The interface for managing Microvellum projects and drawings has 3 views and formats of the projects management UI to select from: simple (a straightforward vertical list), the default Tree view (visit this article for more information on that), and ...
