Component Cabinet Library Release Notes | Build 50.7
The following
release notes apply to Component Cabinet Library, Build 050.7
Additions
Added Products:
Upper Starter Horizontal FF Multi
Carcass
Pullout Base
1 Drawer with Pullout
Pullout Base FF
Upper Starter Split Height
Upper Starter Split Height no Box
Added Subassemblies
Suspension Brackets Corner
Suspension Brackets
Upper Face Frame Split Height
Added a category of nine "Face
Frame Only" products.
Added nine angled transition face frame
cabinet products.
Added six additional "Curved
Front" face frame cabinet products and associated subassemblies.
Added new cabinet product "Inside
Curved Corner Base" and associated curved face frame & door
subassemblies.
Added "Base Quarter Round
Unit" Face Frame cabinet and associated subassemblies.
Added "Base Half Round Unit 4
Door" & "Base Half Round Unit 2 Door" Face Frame
Added Global Variable "Add Wall
Hangers" for a new Wall Hanger feature (Upper Frameless Cabinets
Only).
Added a new Leg Leveler Type called
"Use Hardware Wizard." With this new setting, you can select any
leg leveler and leg leveler base in the hardware inventory from the
Hardware Wizard.
Added new Leg Leveler hardware materials
(Hafele Axilo, Fennel UK Samson). Also added 3D graphics.
Improvements
Improved the product "Base Starter
Horizontal FF Multi Carcass."
Improved the global variable
"G!Disable_Hinge_Lines" so that it now controls 2D elevation
door swing lines for slab doors (in addition to solid wood & mdf).
Ran Audit command in all AutoCAD
template (DWT) files to clean errors.
Resolutions
Resolved an issue where the product
"Valance" was not behaving correctly when using the Toolbox
"Fill Wall with Products" function.
Resolved an issue where the global
variables "Toe_Kick_Difference_Extended" &
"Toe_Kick_Notch_Aligned_to_Bottom_Rail" were not functioning for
face frame cabinets.
- Resolved an issue in the Grass Vionaro subassembly with associative drilling locations at the drawer front.
- Resolved a dynamic drawing issue with face frame subassemblies in metric conditions.
- Resolved an issue with Carcass Subassemblies where parts were receiving edgebanding in situations where it was not required.
Modifications
Modified the Base Assembly, Base
Assembly Pie Cut subassembly to accommodate the new leg leveler feature.
Related Articles
Component Cabinet Library Release Notes | Build 50.6
The following release notes apply to Component Cabinet Library, Build 50.6 Additions Added Hettich Avantech YOU Drawer system to Imperial and Metric Libraries. Learn more. Added Valance Top and Bottom to 1 Door Diagonal Corner Upper and 2 Door Pie ...
Component Cabinet Library Release Notes | Build 50.1
This build of the Component Cabinet Library was an internal release. Additions Added prompt variables and lookup tables inside template Hardware workbook to support new Toolbox hardware counting feature. Added formula data to all CONST, HOLES, ...
Component Cabinet Library Release Notes | Build 50.2
This build of the Component Cabinet Library was an internal release. Additions Added new product to the Miscellaneous category: Trolley. Added three new Costing Reports: MV Cost Report, MV Labor Report, MV Quote Report. Added two new interior ...
Component Cabinet Library Release Notes | Build 50.0
This build of the Component Cabinet Library was an internal release. Additions Added new Shadow Line Finger Pull option. Added new global variables, global LookUpTables, material pointers, and hardware pointers to accommodate legacy closet system ...
Component Cabinet Library Release Notes | Build 50.5
We are excited to announce the updates for the Component Cabinet Library (Build 050.5). Below is a list of the new features and enhancements we've recently made to improve your experience with this product library. Additions Added the ability for ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0419
