Configuration Editor: AutoCAD Options
Dimensioning
Dimension settings will display product dimensions with the value or will include the text "Verify" to the dimension.
Place Dimension on Current Layer – Places the Dimensions on the current AutoCAD layer.
Dimension Layer – Selects the default layer for Dimensions.
Drawing Preference
Controls how the program draws the products when adding from the product library to the AutoCAD drawing file. You can use the Redraw Product command to change how the product is drawn once added to the drawing.
Add 2D Plan Tokens to 3D – Draws a 2D plan view representation of the products alongside the 3D representation.
3D Visual Style
Sets how the drawing environment will be set after a product is drawn. 2D Wire Frame setting provides the best drawing performance. Visual Styles can also be set within the AutoCAD drawing file.
Autodesk Product Association
Click Configure to associate Toolbox Standard Edition to a different AutoCAD version.
Manages how product section update when modifying the 3D representation of the product.
Use Annotative Scaling
Enables Annotative scaling for each drawing created. Use setup text to manage the annotative scaling settings.
Related Articles
Overview: Configuration Editor (Options) Interface
The Configuration Editor (Options) Interface for Microvellum Toolbox is accessible from the Toolbox Setup menu. Using the options contained within, you'll configure general system settings, set up the optimization software you use, set up tool files, ...
Configuration Editor: Utilities Options
This article provides an overview of the options and settings available on the Utilities tab of the Configuration Editor (Options) Interface. For a complete list of available tabs and options visit Overview: Configuration Editor (Options) Interface. ...
Configuration Editor: Processing Options
This article provides an overview of the options and settings available on the Processing tab of the Configuration Editor (Options) Interface. For a complete list of available tabs and options visit Overview: Configuration Editor (Options) Interface. ...
Configuration Editor: General Options
This article provides an overview of the options and settings available on the General tab of the Configuration Editor (Options) Interface. For a complete list of available tabs and options visit Overview: Configuration Editor (Options) Interface. ...
Configuration Editor: Machining Options
This article provides an overview of the options and settings available on the Machining tab of the Configuration Editor (Options) Interface. For a complete list of available tabs and options visit Overview: Configuration Editor (Options) Interface. ...
Recent Articles
Microvellum Release Notes | Build 25.2.0206.641
The following release notes apply to Microvellum build 25.2.0206.641. Item Number Fix An issue was reported regarding item numbers in composite drawings. Users who processed work orders with multiple products reported that the item numbers would ...
Microvellum Release Notes | Build 25.2.0204.641
The following release notes apply to Microvellum build 25.2.0204.641. Toolbox Brand Retirement As part of Microvellum’s ongoing alignment with the values and catalog of INNERGY, and to improve user experience, clarity, and consistency, we have ...
MDF Door Profile Guide
Door Wizard The Door Wizard is a Microvellum feature that enables users to interact with and control the specifics of door related variables, prompts, and available settings. The options available in the door wizard vary depending on the specific ...
Microvellum Foundation Library Release Notes | Build 26.0112
Additions In accordance with Microvellum's new subscription changes, all Face Frame Expansion products and subassemblies, as well as the Range Hood Master product have been added to the full library install and library update zips (now included with ...
Toolbox Release Notes | Build 25.2.0114.641
The following release notes apply to Toolbox build 25.2.0114.641 Processing Center Message Fix Fig. 1: An error message running in the background of the software. An issue was reported within the Processing Center. When processing an order, there ...
