Estimating and Purchasing Optimizer
Establishes the optimizer type to use when estimating material usage in Cost-Based Estimating and Purchasing.
- Nesting - Set the optimizer to a nesting type.
- Sawing - Set the optimizer to a sawing type.
WMF Face Frame Image Size
Sets the default Face Frame Image Size for Windows Metafile creation.
- Size - Set the size for a WMF Face Frame image (px).
Scrap Management
During optimization, the Microvellum Scrap Management System creates a 'scrap material' from what would usually be waste. It provides the ability to add scrap to available inventory for future nest optimizations. Check the Enable Automatic Scrap Management checkbox in the processing station to create and use scrap within the processing center. Enabling scrap management requires the minimum scrap length/width and minimum scrap area for scrap pieces to be set in the processing station.
- Manage Inventory – Clicking this button displays the scrap inventory available. Double-click in any cell in the list view, and you can modify that scrap inventory item. If you right-click, you can remove a scrap piece or add a new piece.
- Manage Storage Location – Manages the storage locations available to locate scrap pieces created through the scrap management system. Select the Manage Storage Location button to display the Material Storage dialog. Right-click within this interface to create or remove a new storage location. Double-click within a cell to edit the name or description of the bin.
- Create Numeric Scrap Handling Code - Create a code for the order/method of how scrap is managed during processing.
- Remove Material Trim from Scrap - This setting impacts scrap dimensions for Reports and Labels. Trim is handled differently, dependent on the saw type. Reports and Labels may not match what is cut. Defaults to on to prevent breaking changes.
Processing Center Part Loading
Select how parts are loaded into the processing station when opening a work order.
- Manually Load Parts - Manually load the parts into the processing station when opening a work order.
- Auto Load All Parts - Automatically load all parts from the project into the processing station when opening a work order.
- Auto Load Parts With Machining - Automatically load only parts from the project with machining attached into the processing station when opening a work order.
- Auto Load Parts Without Machining - Automatically load only parts from the project with no machining attached into the processing station when opening a work order.
- Auto Load Parts By Material - Automatically load parts from the project into the processing station, organized according to material.
Processing Center Grid Options
Select columns for display within the Processing Center.
- Show Part X Data Columns - Enable to display the data columns for the X Data in the processing station.
- Show Buy Out Materials - Enable to display which materials and products are marked as Buy Out in the processing station.
- Show Hardware Materials - Enable to display hardware along with materials in the processing station.
- Show Tooling Errors - Enable to display any errors or missing elements in Tool Files during processing. Disable to ignore tooling error pop-ups.
Processing Center Material Processor
The Material Processor supports the Biesse Winstore system plug in. Here you are able to edit the settings for the SQL and Saw for your Biesse. It also allows you to enter the Max Process Time/Winstore Entry.
