DWG Compare Limitations
Drawing comparison does not support all object types in AutoCAD and AutoCAD specialized toolsets.
Limitations for AutoCAD Object Types
The DWG Compare feature does not support all object types in AutoCAD. The exceptions include OLE objects, cameras, geographic data, GIS objects from Map 3D, non-DWG underlays, images, coordination models, and point clouds.
Limitations in AutoCAD Specialized Toolsets
When performing a comparison, importing electrical and mechanical objects is similar to the copy/paste behavior in AutoCAD, which is different from how the AutoCAD Electrical and AutoCAD Mechanical toolsets normally operate. As a result, some of the toolset components lose their custom functionality.
The following tables describe the primary limitations for the comparing drawings created with the AutoCAD Electrical and AutoCAD Mechanical specialized toolsets.
Limitations with the AutoCAD Electrical Toolset
Electrical objects
Output after using compare import command
Wires
Wires will lose some of the properties like color and size. The wire data is available in the project as layers and cannot be imported into the drawing comparison mode.
Wire number
The wire number is disconnected with the wire. The imported wire number will lose the relationship with the wire.
Source/Destination arrows
The source/destination arrows imported will not have the correct wire numbers. The source arrows and the destination arrows will also lose the relationship to each other.
Schematic terminals
These blocks will retain their electrical properties, however the terminal wire numbers will not be updated.
Balloons
The imported balloons will not be grouped and will be available only as exploded geometric objects.
Limitations with the AutoCAD Mechanical Toolset
Mechanical objects
Mechanical symbols
Importing a mechanical symbol that's attached to an object also imports the associated object. For example, if a weld symbol is attached to a rectangle, importing the weld symbol will also import the rectangle object.
Standard parts
Importing a standard part will not update the Bill of Materials (BOM) unless you also select the associated part reference of the standard part.
Finite Element Analysis (FEA) objects and other calculation objects
Importing an FEA object will not include its mechanical data and the object will be imported as a block.
Limitations with the AutoCAD Architecture Toolset
Architectural objects
General AEC objects
Importing an architectural object (AEC object) that's attached to an AEC object also imports the associated object. For example, if a door or window is attached to a wall, importing the door or window object will also import the associated wall object.
Limitations with the AutoCAD MEP Toolset
General MEP objects
Importing an MEP object that's attached to an MEP object also imports the associated object. For example, if a duct fitting is attached to a duct, importing the duct fitting will also import the associated duct object.
Powered by  AutoCAD ®
