Face Frame Expansion Overview
The Microvellum Face Frame Expansion for the Foundation Library contains a broad collection of various Face Frame cabinet products intended to be used as a starting point for manufactures or create their own catalog. The expansion contains 113 unique products and 25 unique subassemblies that use existing global variables for customizing desired details. Each product also contains dozens or more variables unique to each product for further customization.
Info
As of Microvellum Foundation Library build 26.0112, the Face Frame Library is integrated into the base Microvellum Foundation Library.
Master Products
Master Cabinet FF
Description: Single modular face frame cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  1. Parametric Sizing Width/Height/Depth/Toe Kick Height
  2. Specify Left/Right End Conditions (None/Applied End/Face Frame)
  3. Left/Right Filler variables
  4. Specify Rails/Full Top/Overlay Top
  5. Specify No Bottom/Full Bottom/Overlay Bottom
  6. Specify Finished Left/Right/Back/Top/Bottom
  7. Countertop option with variables tab (generally for drawing representation)
  8. Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Internal Options:
  1. Access to all Component Insert Options
  2. Continuous Shelf Holes option
  3. Add Center Shelf option
Face Options:
  1. Access to all Face Options (No Door/Left Swing/Right Swing/Two Doors/Liftup Door/Drop Down Door/Drawers)
  2. Access to all Foundation Library Door Types & Styles
  3. Overlay/Full Inset Door options with overlay/gap variables
  4. Top Drawer & Double Top Drawer option
  5. Add Top Facia option
Face Frame Options:
  1. Face Frame Options (Standard/Separate Bead/Haunched/Single Panel)
  2. Left/Right Stile Scribe variable for wall or corner conditions
  3. Frame Left/Right Side Overlay Control (Inside/Outside)
  4. Frame Top/Bottom Overlay Control (Inside/Outside)
  5. Frame Left/Right/Top/Bottom Overlay variables
  6. Frame Stile & Rail width variables
  7. Front Left/Right Corner Choices (Standard Left/Corner Notched/Chamfered/Radius)
  8. Frame Stile Left/Right removal options (to use adjacent cabinet stile)
  9. Add Intermediate Stile option (when two doors are present)
Hardware Options:
  1. Ability to change the default Handle Type
  2. Handle Distance from Side/Top/Bottom variables
  3. Horizontal Handle option
  4. Add Lock option
  5. Add Wall Hanger option
Additional Info:
As with any “Master” cabinet product in the Frameless Cabinetry category, each can become a Base, Base Open, Tall, Tall Open, Upper, or Upper Open by the Product Type combo box inside the Advanced Construction Options tab. In the same tab, we can also control the desired construction method for each of the various cabinet parts.
Inside the Material Options tab, we can individually specify a different material for each of the cabinet parts if they differ from what is set in the specification group. We can also control the grain direction for doors, sides, and cabinet backs.
Master Blind Corner Cabinet FF
Description: Single modular face frame blind corner cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  4. Specify Left or Right Blind Corner & Width variable
  5. Specify Rails/Full Top/Overlay Top
  6. Specify No Bottom/Full Bottom/Overlay Bottom
  7. Specify Finished Left/Right/Back/Top/Bottom
  8. Countertop option with variables tab (generally for drawing representation)
  9. Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Internal Options:
  4. Shaped Shelf option to add a shaped cutout to the front of the shelf
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Additional Info: As with any “Master” cabinet product in the Frameless Cabinetry category, each can become a Base, Base Open, Tall, Tall Open, Upper, or Upper Open by the Product Type combo box inside the Advanced Construction Options tab. In the same tab, we can also control the desired construction method for each of the various cabinet parts.
Additional Images:
Master Enclosed Appliance Cabinet FF
Description: Single modular face frame enclosed appliance cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
• Parametric Sizing Width/Height/Depth/Toe Kick Height
• Specify Appliance Opening Height
• Specify Appliance Option (Fridge, Microwave, Dishwasher, Oven)
• Specify Left/Right End Conditions (None/Applied End/Face Frame)
• Left/Right Filler variables
• Specify Rails/Full Top/Overlay Top
• Specify No Bottom/Full Bottom/Overlay Bottom
• Specify Finished Left/Right/Back/Top/Bottom
• Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Internal Options:
Face Options:
  1. Access to Face Options (No Door/Left Swing/Right Swing/Two Doors/Liftup Door)
Face Frame Options:
Hardware Options:
  4. Add Lock option
Additional Images:
Master Transition Angle Cabinet FF
Description: Single modular face frame transition angle cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
• Specify Cabinet Angle Left or Right
• Specify Cabinet Angle OR Left/Right Cabinet Depth
• Specify Left/Right Applied End
• Countertop option with variables tab (generally for drawing representation)
Internal Options:
  1. Access to some Component Insert Options (Shelf Adj, Shelf Fixed)
Face Options:
  1. Access to Face Options (No Door/Left Swing/Right Swing/Two Doors)
Face Frame Options:
  7. Frame Stile Left/Right removal options (to use adjacent cabinet stile)
  8. Add Intermediate Stile option (when two doors are present)
Hardware Options:
  4. Add Lock option
Additional Images:
Master Diagonal Angle Cabinet FF
Description: Single modular face frame diagonal angle cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
• Parametric Sizing Height/Depth/Toe Kick Height
• Specify Full Top/Overlay Top
Internal Options:
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Additional Images:
Master Open Corner End Cabinet FF
Description: Single modular face frame open corner end cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  2. Specify Front Corner Filleted or Chamfered
  3. Specify Front Radius or Chamfer size
  4. Specify Left Hand or Right Hand
  5. Specify Left/Right End Conditions (None/Applied End/Face Frame)
  6. Left/Right Filler variables
  7. Specify Full Top/Overlay Top
  8. Specify No Bottom/Full Bottom/Overlay Bottom
  9. Specify Finished Left/Right/Back/Top/Bottom
  10. Countertop option with variables tab (generally for drawing representation)
  11. Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Internal Options:
Face Frame Options:
Additional Images:
Master 2 Bay Horizontal Cabinet FF
Description: Single modular face frame two bay horizontal cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
Bay 1 & 2 Options:
  2. Access to all Component Insert Options
  3. Continuous Shelf Holes option
  4. Top Drawer option
Face Options:
  1. Access to all Foundation Library Door Types & Styles
  2. Overlay/Full Inset Door options with overlay/gap variables
  3. Add Top Facia option
Face Frame Options:
  6. Frame Stile, Rail, & Intermediate Stiles/Rails width variables
  9. Face Frame Division Overlay Control for center stile (Centered, Left, Right, Double)
Hardware Options:
  4. Add Lock option
The Master 2 Bay Horizontal Cabinet FF is very similar to the Master Horizontal Designer Cabinet FF which has up to 10 bays. This product can only have two bays to keep the internal spreadsheet data as simple & efficient as possible.
Additional Images:
Description: Single modular face frame multi bay horizontal cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  2. Specify up to ten bays wide
  3. Specify Left/Right End Conditions (None/Applied End/Face Frame)
  4. Left/Right Filler variables
Bay 1 thru 10 Options:
Face Options:
Face Frame Options:
  9. Face Frame Division Overlay Control for each individual center stile (Centered, Left, Right, Double)
Hardware Options:
  4. Add Lock option
Additional Images:
Master 2 Bay Vertical Cabinet FF
Description: Single modular face frame two bay vertical cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  7. Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Bay 1 & 2 Options:
  2. Specify Bay Door as Base, Tall, or Upper
  3. Access to all Component Insert Options
  4. Continuous Shelf Holes option
  5. Top Drawer option
Face Options:
Face Frame Options:
  9. Face Frame Fixed Shelf Overlay Control for intermediate rail (No Shelf, Centered, Top, Bottom, Double)
Hardware Options:
  4. Add Lock option
The Master 2 Bay Vertical Cabinet FF is very similar to the Master Vertical Designer Cabinet FF which has up to 10 bays. This product can only have two bays to keep the internal spreadsheet data as simple & efficient as possible.
Additional Images:
Description: Single modular face frame multi bay vertical cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
• Specify up to ten bays high
  3. Specify Bay Door as Base, Tall, or Upper
Face Options:
Face Frame Options:
  9. Face Frame Fixed Shelf Overlay Control for intermediate rails (No Shelf, Centered, Top, Bottom, Double)
Hardware Options:
  4. Add Lock option
Additional Images:
Master Multi Carcase Designer Cabinet FF
Description: Single face frame multi bay multi carcase horizontal cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Additional Images:
Master Upper Split Height Designer Cabinet FF
Description: Single face frame multi bay multi split-height carcase horizontal upper cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  1. Parametric Sizing Width/Height/Depth/Individual Bay Heights
  2. Specify up to five bays wide
Bay 1 thru 5 Options:
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Split Height Options:
  1. Each bay can have an individual unique height. If two adjacent bays have the same height, they will share cabinet bottoms, backs, and face frame bottom rails.
Additional Images:
Master Split Height Designer Cabinet FF
Description: Single face frame multi bay multi split-height carcase horizontal base cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Countertop Options:
  1. Individual Countertops option - Select if you require an individual countertop on each bay.
  2. Appliance Options – Select between Sink, Farmhouse Sink, and gas cooktop
Additional Images:
Master Split Cabinet FF
Description: Single modular face frame split-cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
Internal Options:
  4. Center Shelf Position Value – This determines where the carcase cabinet is split between the upper and lower sections.
Face Options:
Face Frame Options:
Hardware Options:
  4. Add Lock option
Additional Images:
Master Corner Cabinet FF
Description: Single modular face frame pie-cut  corner cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  1. Parametric Sizing Width/Height/Depth/Toe Kick Height/Cabinet Depth Left/Right
  7. Specify Carcase Radius at inside corner
  8. Specify Full Left Rail or Full Right Rail
  9. Countertop option with variables tab (generally for drawing representation)
  10. Access to All Construction Methods, Material Options, Advanced Options, Flatshot Options, 2D Drawing Options, Item Number Options, and Rendering Options
Internal Options:
  1. Access to some Component Insert Options (Shelf Adj, Shelf Fixed, Hanging Rail)
  3. Shaped Shelf option
  4. Add Center Shelf option
Face Options:
  1. Access to Face Options (No Door/Left Swing/Right Swing)
  4. Add Top Facia option
  5. Double Door option
Face Frame Options:
Hardware Options:
  4. Add Lock option
The Pie Cut Distance Left & Right is controlled by the Cabinet Depth Left & Cabinet Depth Right variables.
Additional Images:
Master Diagonal Corner Cabinet FF
Description: Single modular face frame diagonal corner cabinet product. This is a “Master” product capable of being saved back to Library numerous times in unlimited number of different combinations.  This product is included with the Foundation Library Face Frame Expansion.
Main Options:
  7. Add Vertical Rail option for hinge mounting
  8. Specify Carcase Radius at inside corner
Internal Options:
Face Options:
  4. Add Top Facia option (False Front)
Face Frame Options:
  7. Add Intermediate Stile option (when two doors are present)
Hardware Options:
  4. Add Lock option
  6. Ability to change the default Hinge and/or Hinge Plate
The Front Angle & Front Angle Length is controlled by the Cabinet Depth Left & Cabinet Depth Right variables.
Additional Images:
Library Categories
The Face Frame Cabinetry expansion includes sixteen different categories of cabinets. All are spawned from one of the Master Cabinet products outlined above. Below is a breakdown of each of the categories and what cabinets are included in each.
Base Angled Cabinets FF
Base Diagonal Angle Cabinet FF
Base Open Diagonal Angle Cabinet FF
Base Transition Angle Cabinet FF
Base Cabinet Accessories FF
Base Face Frame Applied Panel FF
Box End FF
Base Cabinets FF
Base 1 Door FF
Base 1 Drawer Microwave FF
Base 2 Door FF
Base Blind Corner FF
Base Folding Door Cabinet FF
Base Open Blind Corner FF
Base Open Corner End FF
Base Open FF
Base Open Pigeon Holes FF
Base Open Wine Rack Trellis FF
Base Starter FF
Base Under Counter Oven FF
Base Corner Cabinets FF
Base Corner Cabinet FF
Base Diagonal Corner Cabinet FF
Base Open Corner Cabinet FF
Base Open Diagonal Corner Cabinet FF
Base Door-Drawer Cabinets FF
Base 1 Door 1 Drawer Blind Corner FF
Base 1 Door 1 Drawer FF
Base 2 Door 1 Drawer FF
Base 2 Door 2 Drawer FF
Base Open 1 Drawer FF
Base Open 2 Drawer FF
Base Drawer Bank Cabinet FF
Base 1 Drawer FF
Base 2 Drawer FF
Base 3 Drawer FF
Base 3 Drawer Split Top Drawer FF
Base 4 Drawer FF
Base 4 Drawer Split Top Drawer FF
Base 5 Drawer FF
Base 6 Drawer FF
Base 7 Drawer FF
Counter Height Cabinets FF
Counter Height 1 Door 1 Drawer FF
Counter Height 1 Door FF
Counter Height 2 Door FF
Counter Height Appliance Cabinet FF
Counter Height Folding Door Cabinet FF
Counter Height Corner Cabinets FF
Counter Height Diagonal Corner Cabinet FF
Sink Cabinets FF
Base 1 Door Sink FF
Base 1 Door Sink With False Front FF
Base 2 Door Farmhouse Sink FF
Base 2 Door Sink FF
Base 2 Door Sink With False Front FF
Suspended Cabinets FF
Suspended 1 Drawer FF
Suspended 2 Drawer FF
Suspended Horizontal Designer FF
Suspended Open FF
Suspended Open Horizontal Designer FF
Tall Angled Cabinets FF
Tall Diagonal Angle Cabinet FF
Tall Open Diagonal Angle Cabinet FF
Tall Transition Angle Cabinet FF
Tall Cabinets FF
Tall 1 Door Broom Cabinet FF
Tall 1 Door Double Door FF
Tall 1 Door FF
Tall 1 Door With Fixed Shelf FF
Tall 1 Door With Inner Drawers FF
Tall 2 Door Broom Cabinet FF
Tall 2 Door Double Door FF
Tall 2 Door FF
Tall 2 Door Pantry FF
Tall 2 Door With Fixed Shelf FF
Tall 2 Door With Inner Drawers FF
Tall Blind Corner FF
Tall Folding Door Cabinet FF
Tall Fridge Cabinet FF
Tall Open Blind Corner FF
Tall Open Corner End FF
Tall Open FF
Tall Open Pigeon Holes FF
Tall Open Wine Rack Trellis FF
Tall Pantry With Drawers FF
Tall Starter FF
Tall Corner Cabinets FF
Tall Corner Cabinet FF
Tall Diagonal Corner Cabinet FF
Tall Open Corner Cabinet FF
Tall Open Diagonal Corner Cabinet FF
Upper Angled Cabinets FF
Upper Diagonal Angle Cabinet FF
Upper Open Diagonal Angle Cabinet FF
Upper Transition Angle Cabinet FF
Upper Cabinets FF
Upper 1 Door FF
Upper 2 Door FF
Upper Blind Corner FF
Upper Folding Door Cabinet FF
Upper Open Blind Corner FF
Upper Open Corner End FF
Upper Open FF
Upper Open Pigeon Holes FF
Upper Open Wine Rack Trellis FF
Upper Starter FF
Upper Corner Cabinets FF
Upper Corner Cabinet FF
Upper Diagonal Corner Cabinet FF
Upper Open Corner Cabinet FF
Upper Open Diagonal Corner Cabinet FF
Face Frame Subassemblies
Face Frame Component Inserts
Component Door Drawer FF
Description : Face Frame Component Door-Drawer Insert designed to be added into any product’s square opening.  These are typically used within Designer Cabinets or can be manually added into any custom product’s opening(s). This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  1. Access to Face Options (No Door/Left Swing/Right Swing/Two Doors/Liftup Door/Drop Down Door)
  4. Access to all Foundation Library Drawer Types & Slides with Top/Bottom gap variables
  5. Add/Remove Intermediate Face Frame Rail option
  6. Intermediate Rail Width & Overlay variables
  7. Access to grain direction & Material Options
Additional Info: Insertion point for this subassembly insert is the lower left-hand corner at the front. The width & height are defining the available area that the door(s) are to be located.
Component Doors FF
Description: Face Frame Component Door Insert designed to be added into any product’s square opening.  These are typically used within Designer Cabinets or can be manually added into any custom product’s opening(s). This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  4. Specify Door as Base, Tall, or Upper
  5. Access to grain direction & Material Options
Component Drawers FF
Description: Face Frame Component Drawers Insert designed to be added into any product’s square opening.  These are typically used within Designer Cabinets or can be manually added into any custom product’s opening(s). This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  3. Specify Drawer Quantity 1 thru 7
  5. Specify Drawer Front Heights with Custom Calculator
  6. Add/Remove Intermediate Face Frame Rail option for each drawer
  7. Intermediate Rail Width & Overlay variables
  8. Access to grain direction & Material Options
Face Frame Applied Panels
Applied Panel FF
Description: Applied Panel Subassembly designed for Face Frame cabinet conditions. This subassembly contains two nested subassemblies (Finished Faces or similar) designed to either be used on the Left or Right side of a face frame cabinet product. This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  2. Options for Edge Bottom/Top/Left/Right
  3. Specify Finished End Scribe
  4. Specify Top/Bottom Reveal
  5. Specify amount to extend Top/Front Edge
  6. Access to grain direction & Material Options
Additional Info: Insertion point for this subassembly insert is the lower left-hand (or right-hand) corner at the back (Minus the panel thickness). The Height & Depth are defining the size of the panel (minus the toe kick height and/or other variables).
Face Frame Left Applied End, Face Frame Right Applied End
Description: Face Frame Applied End Subassembly designed for Face Frame cabinet conditions. This subassembly contains up to six nested subassemblies (Finished Faces or similar) depending on the selected number of inset panels. There are two different Left/Right versions designed to either be used on the Left or Right side of a face frame cabinet product. This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  1. Frame Stile & Rail width variables
  2. Specify which Stiles extend to the floor (None, Front, Back, Both) and distance
  3. Specify if bottom rail extends to the floor and distance
  4. Specify Stile scribe amount
Multi Panel Options:
  1. Depending on the condition needed, up to six individual panels inset the frame
  3. Specify if you have an Adjacent Base or Upper Cabinet and Qty of Vertical Panels. Panels will update accordingly with built in Panel Calculation formulas (see image below).
  4. Deselecting “Simple Panel Calculation” allows you to custom specify the panel sizes & locations
Additional Info: Insertion point for this subassembly insert is the lower left-hand (or right-hand) corner at the back (Minus the panel thickness). The Height & Depth are defining the size of the face frame (minus the toe kick height and/or other variables).
Face Frame Standard Cabinet Inserts
Face Frame Separate Bead
Face Frame Modifiers
Face Frame Rail Modifiers
Description: Specialty Face Frame Subassembly designed for Face Frame cabinet conditions. This subassembly contains no actual cut parts but rather a collection of virtual routes design to apply decorative machining to top & bottom rails. This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  1. Top/Bottom Cutout Height
  2. Cutout Offset from Left/Right Stile
  3. Distance between Cutouts
  4. Qty of Cutouts
  5. Options include:
    1. Top Rail Arch
    2. Top Rail Double Arch
    3. Top Rail Scallop
    4. Top Rail Three Sided Notch
    5. Bottom Rail Arch
    6. Bottom Rail Double Arch
    7. Bottom Rail Scallop
    8. Bottom Rail Three Sided Notch
Additional Images:
Face Frame Left Stile Flutes and Profiles, Face Frame Right Stile Flutes and Profiles
Description: Specialty Face Frame Subassembly designed for Face Frame cabinet conditions. This subassembly contains no actual cut parts but rather a collection of virtual routes design to apply decorative machining (flutes) to Left/Right Stiles when it is added to a product. This same subassembly can also apply a decorative VCUT miter profile along the outside edge. This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  1. Add Flutes Left/Right: None, Full Height, Split Height, Top Only, Bottom Only
  2. Flute Qty: 3, 4, 5
  3. Flute Distance From Top/Bottom
  4. Distance Between Flutes (for split height)
  5. Height to Mid Flute Split (for split height)
  6. Flute Length Offset Distance
  7. Fluting Tool
  8. Flute Profile
  9. Flute Depth/ Width
  10. Add FE Left/Right Stile Profile: None, Full Height, Split Height, Top Only, Bottom Only
    1.  Profile Distance From Top/ Bottom
    2.  Distance Between Profiles
    3.  Height to Mid Profile Split
    4.  Profile Depth
    5.  Profile Width
Additional Images:
Face Frame Left Stile Chamfer Corner Flutes, Face Frame Right Stile Chamfer Corner Flutes
Description: Specialty Face Frame Subassembly designed for Face Frame cabinet conditions. This subassembly contains no actual cut parts but rather a collection of virtual routes design to apply decorative machining (flutes) to Left/Right Chamfer Stiles when it is added to a product. This subassembly is included with the Foundation Library Face Frame Expansion.
Options:
  7. Fluting Tool
  8. Flute Profile
Additional Images:
Face Frame Splitters
Division FF
Horizontal Opening Splitter FF
Vertical Opening Splitter FF
Shelf Fixed FF
Face Frames Non Insert
  1. Angled Face Frame
  2. Corner Face Frame
  3. Diagonal Angled Face Frame
  4. Diagonal Face Frame
  5. Face Frame
  6. Face Frame Open Corner
  7. Face Frame Split Height
  8. Face Frame Single Panel Cutout
st Original Remove
    • The Closet/Wardrobe Expansion Overview
      About the Expansion The Microvellum Closet/Wardrobe Expansion contains a wide collection of closet/wardrobe products, inserts, hardware, and customization options to complement the Foundation Library. This article will provide you with an overview of ...
    • The Staircase Expansion Overview
      About the Expansion The Microvellum Staircase Expansion contains a collection of staircase layouts to plug into the Foundation Library. This article will provide you with an overview of the Staircase Expansion and contains a listing of products, ...
    • The Range Hood - Add-on
      About the Library Add-on This is a “Master” Range Hood product capable of being used as is or saved back to the library numerous times in unlimited number of different combinations. This Library Add-on is compatible with the Foundation Library. This ...
    • Overview: Face Frame Images 4 (Improvements)
      This is the fourth article in the series, giving an overview of how to configure the custom face frame images in the default Microvellum shipping libraries of build 046.2 and higher. The first articles in the series discussed how to use the default ...
    • Overview & Tutorials: Face Frame Images 3 (Customizing in the Spreadsheet)
      This is the third article in the series giving an overview of how to configure the custom face frame images in the default Microvellum shipping libraries of build 046.2 and higher. The first articles in the series discussed how to use the default ...
    • Microvellum Remote Desktop (RDP) and RDS Compatibility
      Microvellum BSB and Microvellum AC support remote desktop connections to dedicated Windows computers, including physical workstations and persistent virtual desktops. However, Microvellum does not support multi-session environments, where multiple ...
    • Microvellum Foundation Library Release Notes | Build 26.1030
      The following release notes apply to Microvellum Foundation Library build 26.1030. Modifications The Nover Krome Premium Plus drawer system's Black finish option has been removed from the Hardware Library, as this system is only offered in White ...
    • Microvellum Foundation Library Release Notes | Build 26.0929
      The following release notes apply to Microvellum Foundation Library build 26.0929. Additions The Furnware AERO drawer system has been added to the library catalogue for the AU, NZ, and All region options. Machining and reporting have been developed ...
    • Microvellum Subassemblies Guide
      1. What is a Subassembly? Subassemblies are one of the most flexible parts of Microvellum, allowing you to reuse a component — a drawer box, a door, a hardware group — across many products without rebuilding it each time. That flexibility is derived ...
    • Microvellum Projects and Drawings Grid View
      The interface for managing Microvellum projects and drawings has 3 views and formats of the projects management UI to select from: simple (a straightforward vertical list), the default Tree view (visit this article for more information on that), and ...
