Microvellum’s Foundation Library is built on the premise of providing our users with the best quality hardware for their construction projects, be they commercial, residential, or anything otherwise. As such, Toolbox has hardware from multiple brands integrated into its extensive library catalogue, to best reflect the most popular hardware currently available on the market.
Richelieu is a leading manufacturer and distributor of specialty hardware based in North America, with a large catalog of products used across multiple industries. Microvellum has incorporated a sizable amount of Richelieu hardware into the Foundation Library, including drawer slides, drawer systems, hinges, and a lift system, comprising over 4% of the Foundation Library’s overall catalog of hardware at the time of writing.
Drawer Slides
Microvellum’s Foundation Library, at the time of writing, contains 2 major lines of concealed Richelieu brand drawer slides, with two major lines: the Richelieu Evolution series (comprised of the Evolution 815 and 818), and standard concealed Richelieu slides (comprised of the 823, 825, and 828).
The Richelieu Evolution series are a set of undermount drawer slides with a built-in soft close mechanism, telescopic movement, and a load bearing capacity of 35 kg (77 lbs.) All slides come in pairs and can be added to any corresponding drawer box or drawer system. For more information on the Richelieu Evolution series, please visit Richelieu’s
official website.
The Microvellum Foundation Library carries the Richelieu Evolution with the following options for client customization:
Support for 13 drawer length options (5 options for the 815, 7 options for the 818):
- 229mm (815) (9”)
- 305mm (815) (12”)
- 381mm (815) (15”)
- 457mm (815) (18”)
- 533mm (815) (21”)
- 270mm (818) (10”)
- 300mm (818) (12”)
- 350mm (818) (14”)
- 400mm (818) (16”)
- 450mm (818) (18”)
- 500mm (818) (20”)
- 550mm (818) (22”)
Option to add 4-way adjustable locking device (818 only).
Toolbox Hardware List
Evolution 815
- Drawer Slide Richelieu 815EV229 (Pair)
- Drawer Slide Richelieu 815EV305 (Pair)
- Drawer Slide Richelieu 815EV381 (Pair)
- Drawer Slide Richelieu 815EV457 (Pair)
- Drawer Slide Richelieu 815EV533 (Pair)
Evolution 818
- Drawer Slide Richelieu 818EV270 (Pair)
- Drawer Slide Richelieu 818EV300 (Pair)
- Drawer Slide Richelieu 818EV350 (Pair)
- Drawer Slide Richelieu 818EV400 (Pair)
- Drawer Slide Richelieu 818EV450 (Pair)
- Drawer Slide Richelieu 818EV500 (Pair)
- Drawer Slide Richelieu 818EV550 (Pair)
- Richelieu Front Locking Device 818-Left
- Richelieu Front Locking Device 818-Right
The 823, 825, and 828 series are concealed drawer slides offering full synchronized extension and a built-in soft close mechanism, designed for usage with wooden drawer boxes or drawer systems like the Richelieu Optimiz-R. For more information on
823,
825, or
828, please visit Richelieu’s official website. All 3 slides offer tool-free adjustment and have a load bearing capacity of 45 KG (100 lbs.)
The Foundation Library contains the 823, 825, and 828 with the following options for client customization:
13 different drawer length options (5 different length options for the 823 & 825, 9 different length options for the 828):
- 305mm (823 & 825) (12”)
- 381mm (823 & 825) (15”)
- 457mm (823 & 825) (18”)
- 533mm (823 & 825) (21”)
- 270mm (828) (10”)
- 300mm (828) (12”)
- 350mm (828) (14”)
- 400mm (828) (16”)
- 450mm (828) (18”)
- 500mm (828) (20”)
- 550mm (828) (22”)
- 600mm (828) (24”)
- 650mm (828) (26”)
Matching locking devices for all lengths
Locking devices for a narrow drawer configuration (825 and 828 only)
- Drawer Slide Richelieu 823305 (Pair)
- Drawer Slide Richelieu 823381 (Pair)
- Drawer Slide Richelieu 823457 (Pair)
- Drawer Slide Richelieu 823533 (Pair)
- Drawer Slide Richelieu 825305 (Pair)
- Drawer Slide Richelieu 825381 (Pair)
- Drawer Slide Richelieu 825457 (Pair)
- Drawer Slide Richelieu 825533 (Pair)
- Drawer Slide Richelieu 828270 (Pair)
- Drawer Slide Richelieu 828300 (Pair)
- Drawer Slide Richelieu 828350 (Pair)
- Drawer Slide Richelieu 828400 (Pair)
- Drawer Slide Richelieu 828450 (Pair)
- Drawer Slide Richelieu 828500 (Pair)
- Drawer Slide Richelieu 828550 (Pair)
- Drawer Slide Richelieu 828600 (Pair)
- Drawer Slide Richelieu 828650 (Pair)
- Richelieu Front Locking Device 823-Left
- Richelieu Front Locking Device 823-Right
- Richelieu Front Locking Device 825-Left
- Richelieu Front Locking Device 825-Right
- Richelieu Front Locking Device 825-Narrow Drawer Left
- Richelieu Front Locking Device 825-Narrow Drawer Right
- Richelieu Front Locking Device 828-Left
- Richelieu Front Locking Device 828-Right
- Richelieu Front Locking Device 828-Narrow Drawer Left
- Richelieu Front Locking Device 828-Narrow Drawer Right
Drawer Systems
Microvellum's Foundation Library contains 3 Richelieu brand drawer systems. The options listed here are available to users by default, open for use by enabling "Drawer Options" under the product prompts, or else can be set via the global variables. At the time of writing, the Richelieu brand drawer systems available are: the Richelieu Axial, 908, and Optimiz-R.
An economical double-walled metal drawer system with a built-in soft-closing mechanism and dual-synchronizing technology incorporated into its design, the Richelieu 908 drawer is available for incorporation into a wide variety of applications, with a load bearing capacity of up to 35 kg (77 lbs.) To learn more about the Richelieu 908, please visit Richelieu’s
official website.
The Richelieu 908 is available in the Foundation Library with the following options for client customization:
4 drawer height options:
- 84mm (3 ½”)
- 116mm (4 ¾”)
- 167mm (7 ¼”)
- 199mm (9 ¾”)
7 drawer length options:
- 270mm (10”)
- 300mm (12”)
- 350mm (14”)
- 400mm (16”)
- 450mm (18”)
- 500mm (20”)
- 550mm (22”)
Support for Gallery Rail configuration.
Accompanying interior fixing brackets and internal crosses/fronts (for Gallery Rail configuration).
2 finish options:
- White
- Gray
- Interior Fixing Bracket Richelieu 908 116 Pair Gray
- Interior Fixing Bracket Richelieu 908 135 Pair Gray
- Interior Fixing Bracket Richelieu 908 135 Pair White
- Interior Fixing Bracket Richelieu 908 199 Pair Gray
- Interior Fixing Bracket Richelieu 908 199 Pair White
- Interior Fixing Bracket Richelieu 908 84 Pair Gray
- Interior Fixing Bracket Richelieu 908 84 Pair White
- Richelieu 908 Drawer Kit 84 270mm 35kg Gray
- Richelieu 908 Drawer Kit 84 270mm 35kg White
- Richelieu 908 Drawer Kit 84 300mm 35kg Gray
- Richelieu 908 Drawer Kit 84 300mm 35kg White
- Richelieu 908 Drawer Kit 84 350mm 35kg Gray
- Richelieu 908 Drawer Kit 84 350mm 35kg White
- Richelieu 908 Drawer Kit 84 400mm 35kg Gray
- Richelieu 908 Drawer Kit 84 400mm 35kg White
- Richelieu 908 Drawer Kit 84 450mm 35kg Gray
- Richelieu 908 Drawer Kit 84 450mm 35kg White
- Richelieu 908 Drawer Kit 84 500mm 35kg Gray
- Richelieu 908 Drawer Kit 84 500mm 35kg White
- Richelieu 908 Drawer Kit 84 550mm 35kg Gray
- Richelieu 908 Drawer Kit 84 550mm 35kg White
- Richelieu 908 Drawer Kit 135 270mm 35kg Gray
- Richelieu 908 Drawer Kit 135 270mm 35kg White
- Richelieu 908 Drawer Kit 135 300mm 35kg Gray
- Richelieu 908 Drawer Kit 135 300mm 35kg White
- Richelieu 908 Drawer Kit 135 350mm 35kg Gray
- Richelieu 908 Drawer Kit 135 350mm 35kg White
- Richelieu 908 Drawer Kit 135 400mm 35kg Gray
- Richelieu 908 Drawer Kit 135 400mm 35kg White
- Richelieu 908 Drawer Kit 135 450mm 35kg Gray
- Richelieu 908 Drawer Kit 135 450mm 35kg White
- Richelieu 908 Drawer Kit 135 500mm 35kg Gray
- Richelieu 908 Drawer Kit 135 500mm 35kg White
- Richelieu 908 Drawer Kit 135 550mm 35kg Gray
- Richelieu 908 Drawer Kit 135 550mm 35kg White
- Richelieu 908 Drawer Kit 199 270mm 35kg Gray
- Richelieu 908 Drawer Kit 199 270mm 35kg White
- Richelieu 908 Drawer Kit 199 300mm 35kg Gray
- Richelieu 908 Drawer Kit 199 300mm 35kg White
- Richelieu 908 Drawer Kit 199 350mm 35kg Gray
- Richelieu 908 Drawer Kit 199 350mm 35kg White
- Richelieu 908 Drawer Kit 199 400mm 35kg Gray
- Richelieu 908 Drawer Kit 199 400mm 35kg White
- Richelieu 908 Drawer Kit 199 450mm 35kg Gray
- Richelieu 908 Drawer Kit 199 450mm 35kg White
- Richelieu 908 Drawer Kit 199 500mm 35kg Gray
- Richelieu 908 Drawer Kit 199 500mm 35kg White
- Richelieu 908 Drawer Kit 199 550mm 35kg Gray
- Richelieu 908 Drawer Kit 199 550mm 35kg White
- Richelieu 908 Gallery Rail 270 Gray
- Richelieu 908 Gallery Rail 270 White
- Richelieu 908 Gallery Rail 300 Gray
- Richelieu 908 Gallery Rail 300 White
- Richelieu 908 Gallery Rail 350 Gray
- Richelieu 908 Gallery Rail 350 White
- Richelieu 908 Gallery Rail 400 Gray
- Richelieu 908 Gallery Rail 400 White
- Richelieu 908 Gallery Rail 450 Gray
- Richelieu 908 Gallery Rail 450 White
- Richelieu 908 Gallery Rail 500 Gray
- Richelieu 908 Gallery Rail 500 White
- Richelieu 908 Gallery Rail 550 Gray
- Richelieu 908 Gallery Rail 550 White
- Richelieu 908 Internal Cross Gallery Rail Gray
- Richelieu 908 Internal Cross Gallery Rail White
- Richelieu 908 Internal Front Gray
- Richelieu 908 Internal Front White
Hinges
Microvellum’s Foundation Library, at the time of writing, carries a variety of hinges belonging to a singular Richelieu product line: the Richelieu RCS hinges. This series of hinges can be applied to both frameless and face frame products.
The Richelieu RCS series of hinges are a set of adjustable Euro hinges with a wide range of angles and configurations to ensure that there is a hinge for any application, be it full overlay, half overlay, inset, or more. The hinges come with an optional soft-closing mechanism, and configurations for both frameless and face frame cabinetry. To learn more about Richelieu’s RCS series of hinges, please visit Richelieu’s
official website.
The Microvellum Foundation Library carries the RCS hinges with the following options for client usage and customization:
7 different hinge options:
- RCS 30°
- RCS 45°
- RCS 95°
- RCS 95 Mini°
- RCS 103°
- RCS 105°
- RCS 165°
Face Frame Overlay Hinge Options available in with Dowel or Screw-On.
Full range of mounting plates with options for:
- Eccentric Adjustment
- Face Frame
- Euro Screws
- Screw-In
- Expando
All options can be modified to either inset, full overlay, or half overlay.
All options have configurations for soft-closing or spring-closing.
Face Frame
- Hinge FF Richelieu RCS Dowel .5in Overlay
- Hinge FF Richelieu RCS Dowel .75in Overlay
- Hinge FF Richelieu RCS Dowel 1.25in Overlay
- Hinge FF Richelieu RCS Dowel 1.3125in Overlay
- Hinge FF Richelieu RCS Dowel 1.375in Overlay
- Hinge FF Richelieu RCS Dowel 1.5in Overlay
- Hinge FF Richelieu RCS Screw-On .5in Overlay
- Hinge FF Richelieu RCS Screw-On .75in Overlay
- Hinge FF Richelieu RCS Screw-On 1.25in Overlay
- Hinge FF Richelieu RCS Screw-On 1.3125in Overlay
- Hinge FF Richelieu RCS Screw-On 1.375in Overlay
- Hinge FF Richelieu RCS Screw-On 1.5in Overlay
Mounting Plates
- Hinge Plate Richelieu RCS Eccentric Adjustment Euro Screws 0mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Euro Screws 2mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Euro Screws 4mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Expando 0mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Expando 2mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Expando 4mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Screw-In 0mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Screw-In 2mm
- Hinge Plate Richelieu RCS Eccentric Adjustment Screw-In 4mm
- Hinge Plate Richelieu RCS Euro Screws 0mm
- Hinge Plate Richelieu RCS Euro Screws 2mm
- Hinge Plate Richelieu RCS Euro Screws 4mm
- Hinge Plate Richelieu RCS Expando 0mm
- Hinge Plate Richelieu RCS Expando 2mm
- Hinge Plate Richelieu RCS Expando 4mm
- Hinge Plate Richelieu RCS Face Frame Screw-In 0mm
- Hinge Plate Richelieu RCS Face Frame Screw-In 3mm
- Hinge Plate Richelieu RCS Face Frame Screw-In 6mm
- Hinge Plate Richelieu RCS Face Frame Screw-In Eccentric Adj 0mm
- Hinge Plate Richelieu RCS Face Frame Screw-In Eccentric Adj 3mm
- Hinge Plate Richelieu RCS Face Frame Screw-In Eccentric Adj 6mm
- Hinge Plate Richelieu RCS Screw-In 0mm
- Hinge Plate Richelieu RCS Screw-In 2mm
- Hinge Plate Richelieu RCS Screw-In 4mm
RCS 103°
- Hinge Richelieu RCS 103° Dowel_Soft Closing
- Hinge Richelieu RCS 103° Dowel_Spring Closing
- Hinge Richelieu RCS 103° Screw-On_Soft Closing
- Hinge Richelieu RCS 103° Screw-On_Spring Closing
RCS 105°
- Hinge Richelieu RCS 105° Dowel_Full Overlay_Soft Closing
- Hinge Richelieu RCS 105° Dowel_Full Overlay_Spring Closing
- Hinge Richelieu RCS 105° Dowel_Half Overlay_Soft Closing
- Hinge Richelieu RCS 105° Dowel_Half Overlay_Spring Closing
- Hinge Richelieu RCS 105° Dowel_Inset_Soft Closing
- Hinge Richelieu RCS 105° Dowel_Inset_Spring Closing
- Hinge Richelieu RCS 105° Screw-On_Full Overlay_Soft Closing
- Hinge Richelieu RCS 105° Screw-On_Full Overlay_Spring Closing
- Hinge Richelieu RCS 105° Screw-On_Half Overlay_Soft Closing
- Hinge Richelieu RCS 105° Screw-On_Half Overlay_Spring Closing
- Hinge Richelieu RCS 105° Screw-On_Inset_Soft Closing
- Hinge Richelieu RCS 105° Screw-On_Inset_Spring Closing
- Hinge Richelieu RCS 110° Screw-On_Full Overlay_Soft Closing
RCS 165°
- Hinge Richelieu RCS 165° Dowel_Soft Closing
- Hinge Richelieu RCS 165° Dowel_Spring Closing
- Hinge Richelieu RCS 165° Screw-On_Soft Closing
RCS 30°
- Hinge Richelieu RCS 30° Dowel
- Hinge Richelieu RCS 30° Screw-On
RCS 45°
- Hinge Richelieu RCS 45° Angled Dowel_Soft Closing
- Hinge Richelieu RCS 45° Angled Dowel_Spring Closing
- Hinge Richelieu RCS 45° Angled Screw-On_Soft Closing
RCS 95°/95° Mini
- Hinge Richelieu RCS 95° Clip-On_Soft Closing
- Hinge Richelieu RCS 95° Clip-On_Spring Closing
- Hinge Richelieu RCS Mini 95° Screw-On_Full Overlay_Soft Closing
- Hinge Richelieu RCS Mini 95° Screw-On_Half Overlay_Soft Closing
- Hinge Richelieu RCS Mini 95° Screw-On_Inset_Soft Closing
Lift Systems
The Microvellum Foundation Library carries Richelieu's forerunner lift system, the Richelieu Atmos aiR lift system, for incorporation into client projects.
The Atmos aiR is Richelieu’s premiere lift system, a 107° ascending cabinet opening system with three different power factors and a simple assembly process. To learn more about the Atmos aiR, please visit Richelieu’s
official website.
The Microvellum Foundation Library comes with the full range of options available for the Atmos aiR for client use and customization:
3 power factors:
- Light (580-1105)
- Medium (1105-1920)
- Heavy (1920-3500)
3 finishes:
- Black
- Gray
- White
- Richelieu Atmos Air Light Weight 580-1105 Black
- Richelieu Atmos Air Light Weight 580-1105 Gray
- Richelieu Atmos Air Light Weight 580-1105 White
- Richelieu Atmos Air Medium Weight 1105-1920 Black
- Richelieu Atmos Air Medium Weight 1105-1920 Gray
- Richelieu Atmos Air Medium Weight 1105-1920 White
- Richelieu Atmos Air Heavy Weight 1920-3500 Black
- Richelieu Atmos Air Heavy Weight 1920-3500 Gray
- Richelieu Atmos Air Heavy Weight 1920-3500 White
