Foundation Library Subassembly Inserts
This article will provide you with an overview of the Subassembly Inserts included within Microvellum's Foundation Library. Each subassembly has its own set of configurable options and can be inserted into a variety of Foundation Library products, including products from the Closet/Wardrobe Library Expansion.
Internal Inserts
Shelf Adj
Description: Adjustable Shelf Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Parametric Sizing Width/Height/Depth
·         Shelf Qty to specify the number of shelves
·         Shelf Height Calculator
·         Shelf Setback variable to push shelves in from the opening face
·         Continuous hole pattern or individual line bores per shelf
·         Shelf Standards option
·         Shelf edge options for Edgebanding or Lip Up / Lip Down
·         Optional parametric shaped edge detail
·         Shelf hole variables for locations & spacings
·         Access to Material Options
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the shelves can be located.
Shelf Fixed
Description: Fixed Shelf Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Access to All Construction Methods
Division With Adj Shelves
Description: Single Division with Adjustable Shelves Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Division Width Calculator to specify the two vertical opening sizes
·         Division Setback variable to push division & shelves in from opening face
·         Double Division option
·         Full Top Shelf above Division option
·         Use the Rail Notch option if you require the divisions to create a locating notch in the rails above
·         Specify Shelves Left, Right, or Both
·         Shelf edge options for Edgebanding or Lip Up / Lip Down*
·         Shelf hole variables for locations & spacings*
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the parts are located. *Adjustable shelves originate from the Shelf Adj insert (nested subassembly).
Division With Fixed Shelves
Description: Single Division with Fixed Shelves Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
Additional Info: The insertion point for this subassembly insert is the lower left-hand corner at the front. The width/height/depth are defining the available area that the parts are located.   *Fixed shelves originate from the Shelf Fixed insert (nested subassembly).
Divisions
Description:  Division(s) Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Division Qty to specify the number of divisions
·         Division Width Calculator to specify the vertical opening sizes & locations
·         Division Setback variable to push division(s) in from the opening face
Pigeon Holes
Description:  Pigeon Hole Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Pigeon Hole Shelf Qty
·         Pigeon Hole Division Qty
·         Shelf Height Calculator to specify the horizontal opening sizes & locations
·         Joint Clearance and Joint Tolerance variables to calibrate the machining
·         Division & Shelf Setback variables to push parts in from the opening face
Hanging Rail, Double Hanging Rail
Description:  Hanging Rail Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Hanging Rail Qty up to four
·         Rail location/position variables
·         Side Clearance variable to deduct from the rail for the support hardware
·         Options to change Hanging Rail Type & Support hardware
·         Top fixed shelf option to align above the rail
·         Option to display 3D clothes hangers
Horizontal Opening Splitter Component
Description:  Horizontal Opening Splitter Subassembly Internal Insert designed to be added into any product’s square opening.  The intent of this insert is to horizontally “split” any opening with vertical divisions. This subassembly is included with the base Foundation Library.
Main Options:
·         Division Width Calculator to specify the opening sizes & locations
·         Component Setback variable to push parts in from opening face
Additional Info:  Each bay has access to six Foundation Library Component Inserts (Shelf ADJ, Shelf Fixed, Divisions, Pigeon Holes, Wine Rack Trellis, or Hanging Rail).
Vertical Opening Splitter Component
Description:  Vertical Opening Splitter Subassembly Internal Insert designed to be added into any product’s square opening.  The intent of this insert is to vertically “split” any opening with horizontal fixed shelves. This subassembly is included with the base Foundation Library.
Main Options:
·         Vertical Bay Calculator to specify the opening sizes & locations
Wine Rack Trellis
Description:  Wine Rack Trellis Subassembly Internal Insert designed to be added into any product’s square opening.  This subassembly is included with the base Foundation Library.
Main Options:
·         Opening Size Variable
·         Full Shelves or Lattice
·         Router Clearance and Router Tolerance variables to calibrate the machining
·         Shelf Setback variable to push parts in from opening face
