How to Import a Library using Database Management
NOTICE: The Library Import function is a powerful tool that modifies large sections of data in the current configuration. ALWAYS back up your data before executing a Library Import.
The Library Import functionality of Database Management is designed to import into configurations already containing the same type of library. For example, it is
OK to import a
Component Cabinet Library into a configuration already containing a
Component Cabinet Library. However, this tool should
NOT be used to import a
Foundation Library into a configuration containing a
Component Cabinet Library or vice versa. Depending on the source library and destination database, additional development may be required after import to successfully set up the new library. For more information, please visit the
Microvellum Knowledge Network.
The articles in this section of the Knowledge Base involve importing and exporting from the Database Management window. For general information regarding the Database Management tool, or how to access it, see
Database Management Utilities (Overview).
This simplified article provides a brief tutorial for importing a Library using the Database Management Utility.
Fig. 01 – Database Management Utility – Import Library
- Select IMPORT from Selected Source to Current Configuration > browse to the file location containing the MicrovellumFactory.sdf to be imported > select the MicrovellumFactory.sdf.
- Select the Libraries tab.
- The middle panel will populate with data from the selected database. Select the Library to be imported from this middle panel.
When pulling from an archival database, chances are not everything in the external database needs to be imported. The middle panel in the image above allows you to select only the items you wish to import. The items selected appear in the panel on the right. Items can be selected from multiple categories at once.
- Select Transfer.
Additional Options
When importing a library, the following Additional Options are available:
Fig. 02 – Additional Options when Importing a Library
- Transfer All Hardware Drawings – Check or uncheck this box to control the automatic transfer of all hardware drawings associated with a library or project. If the materials are not transferred, errors may be generated after the items have been imported, when working with the data on another system.
Any desired Additional Options should be selected BEFORE the transfer.
Resolving Duplicates
When importing from a database that includes data duplicated from the Factory Database, like an archival database, the Resolve Duplicate Names window appears.
- Skip – Does not change the existing item, and an additional item is not added. The item is ignored.
- Replace – Replaces the item in the target location that has the duplicate name.
- Keep Both – Appends to the target location. A new name must be given to the item.
Fig. 04 – New Name
Anytime a Library is imported, the program should be restarted before any other action is performed.
Fig. 05 – Restart Software Pop-Up
Related Articles
How to Import a Project using Database Management
NOTICE: The Import function of Database Management is a powerful tool that modifies data in the current configuration. ALWAYS back up your data before executing a data Import. The articles in this section of the Knowledge Base involve importing and ...
Database Management Utilities (Reference)
NOTICE: The Database Management Utility is a powerful tool that modifies large sections of data in the current configuration. ALWAYS back up your data before performing a data import. The Library Import functionality of Database Management is ...
How to Import Reports using Database Management
How to Import Subassemblies using Database Management
How to Import Graphics using Database Management
Recent Articles
Toolbox Release Notes | Build 23.1.1205.642
The following release notes apply to Toolbox build 23.1.1205.642 New FLA Licenses The software has been given a number of overhauls to integrate and function with the new SLS system. Users with software serial numbers for all installed and activated ...
About Microvellum Interface
The following information applies to Microvellum software builds 23.1.1205.642 and beyond. The About Microvellum User Interface displays information and links related to your Microvellum software, company account details and other information and ...
Toolbox Release Notes | Build 23.1.1120.641
The following release notes apply to Toolbox build 23.1.1120.641 New Report Group Option Figure 1: Report Groups (All Batches) A new option has been added within the processing center to assist in streamlining user reports. The option Report Groups ...
Master Bathroom Partition Overview
The Master Bathroom Partition The Master Bathroom Partition product is an array design for toilet and shower bay applications. This includes the proper interior width and depth set for the partition spacing and their function. Each bay has the ...
Microvellum Foundation Library Release Notes | Build 23.1114
Special Note #1: Highly recommend updating Toolbox to build 23.1.1010 or newer as this library update zip includes new features only available to users running this TB version (or newer). Previous versions will not import categorized materials now ...
