Installing Toolbox
Installing Toolbox
Below is a systematic guide for installing Microvellum Toolbox. Before installation, we recommend reviewing our  Pre-Installation Instructions  and  System Requirements.
1. Right-click the Setup.exe file and select “Run as administrator."
2. An interface containing the End-User License Agreement (EULA) will appear, read and check box to agree to the Terms of Use, click next.
3. Configure the desired installation path and select "Install".
4. Once the installation reaches 100% a notification will appear to restart your computer to finish the installation process. You do not have to restart your computer immediately but will need to restart your computer to finish the installation process.
5. A Toolbox shortcut icon will now appear on your desktop.
Info
This article explained how to install Toolbox software on your desktop. If looking for information on installing the Microvellum Foundation Library, updating the Microvellum Foundation Library, updating your Toolbox build, installing Toolbox AC (AutoCAD Companion), or uninstalling Toolbox from your device, consult the following articles:
    • Preparing Your Computer to Install Toolbox
      This tutorial demonstrates the steps recommend prior to installing Microvellum Toolbox and Toolbox AC (AutoCAD Companion). Prior to installing an update, we advise backing up your current data before initiating the process detailed below. Due to ...
    • How to Install Toolbox AC (AutoCAD Companion)
      Below is a systematic guide for installing Toolbox AC. Before installation, we recommend reviewing our Pre-Installation Instructions and System Requirements . Right-click on the Setup.exe file and select “Run as administrator”. Observe the initial ...
    • Installing Toolbox BSB
      This article explains the process for installing Toolbox BSB. Before beginning installation, we recommend reviewing the system requirements for BSB, to ensure your device meets the minimum hardware requirements. Toolbox BSB is not compatible with ...
    • Preparing to Install Microvellum Software
      The steps listed below should be finished before installing any Microvellum software, including Toolbox, Production, and also before installing a program update. Following these pre-installation steps will prevent "error code 1603" & “Cannot find ...
    • How to Install the Foundation Library
      This article provides details on the process of installing the Microvellum Foundation Library. Install 1. Download either the Imperial or Metric library from the Microvellum Portal. To locate these downloads, open the Software Management page, ...
    • Toolbox Release Notes | Build 25.1.1218.641
      The following release notes apply to Toolbox build 25.1.1218.641 Part Properties Fixes A handful of issues centered around the Part Properties interface have been resolved: The Reference for Measurement tool in the interface has been fully removed ...
    • Transferring Global Variables to a new Library
      This article will explain the process of transferring customized Global Variables from your current library to a new installation of the Microvellum Foundation Library. The G! Workbook The Foundation Library contains all standard and custom data in ...
    • Microvellum Foundation Library Release Notes | Build 25.1121
      The following release notes apply to the Microvellum Foundation Library build 25.1121. Additions Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category. Added the Nesting Optimization Report Select Processing ...
    • Toolbox Release Notes | Build 25.1.1204.641
      The following release notes apply to Toolbox build 25.1.1204.641 Toolbox Login Screen Update Fig. 1: The updated Toolbox Login interface. The Toolbox Login interface has had several changes applied to it to enhance its usability and allow for greater ...
    • Toolbox Release Notes | Build 25.1.1120.641
      The following release notes apply to Toolbox build 25.1.1120.641 Mouse Wheel Fix There was a reported issue in certain interfaces (such as report groups) in which hovering over a dropdown menu (such as Output Type) would result in the options within ...
