Issue: Slow Performance & Crashes Associated with Antivirus & Firewall
Microvellum and AutoCAD
To minimize performance issues and crashes associated with antivirus software, we advise the following steps.
  1. Exclude these Microvellum folders:
    C:\Program Files\Microvellum
    C:\Users\<username>\AppData\Roaming\Microvellum
    C:\Users\<username>\AppData\Local\Microvellum
    C:\file\path\to\microvellum\data
    (e.g., C:\Microvellum\Common Microvellum Data\Imperial\049_0)
  2. If running a standard version AutoCad, exclude these files in addition to the previous files excluded.
    C:\Program Files\Autodesk
    C:\Users\<username>\AppData\Roaming\Autodesk
    C:\Users\<username>\AppData\Local\Autodesk
  3. Exclude these application files (location will vary depending on where it's installed):
    Toolbox BSB: bricscad_bsb.exe
    (e.g., C:\Program Files\Microvellum\Toolbox V25 en_US\bricscad_bsb.exe)
     Toolbox OEM: Toolbox.exe
    (e.g., C:\Program Files\Microvellum\Toolbox OEM 2017\Toolbox.exe)
    ERP: Micromanager.exe
    (e.g., C:\Program Files\Microvellum\Micromanager\Micromanager.exe)
    Toolbox with Standard AutoCad: acad.exe
    (e.g., C:\Program Files\Autodesk\AutoCAD 2016\acad.exe)
  4. Here are file type exclusions that will help as well:
    *.Fas, *.lsp, *.3ds, *.wmf, *.sdf, *.ac$, *.apj, *.bak, *.ctb, *.cui, *.cuix, *.dcl, *.dst, *.dwf, *.dwg, *.dwl, *.dwl2, *.dwt, *.fbx, *.ipt, *.lin, *.ma, *.mat, *.max, *.mb, *.mns, *.mnu, *.pat, *.pgp, *.rfa, *.rft, *.rte, *.rvt, *.shp, *.shx, *.stb, *.sv$
If you have centralized antivirus management, you should be able to push these to other machines. If not, most antivirus programs will allow you to export and import exception lists.
SQL Server
To minimize the performance issues and crashes often associated with antivirus it would be advisable to do the following for your SQL server:
Info
These Microvellum recommendations mirror those from Microsoft.
  1. Configure the Windows Firewall to Allow SQL Server Access
  2. Configure a Windows Firewall for Database Engine Access
  3. How to choose antivirus software to run on computers that are running SQL Server
Windows Firewall
What traffic should you allow through the firewall?
The default ports and protocols used by SQL Server services are:
Port
Protocol
Description
80
TCP
Default TCP Port used by Reporting Services
1433
TCP
Default TCP Port used by Database Engine
1434
UDP
Default UDP Port used by SQL Server Browser Service
1434
TCP
Default TCP Port used by Dedicated Admin Connection (DAC)
2382
TCP
When running Analysis Services named instance or running AS in SharePoint mode.
2383
TCP
Analysis Services default TCP port for clustered or standalone instances.
If you're running multiple instances of SQL Server and using different TCP ports for each, you also need to add them to the list above. When using the Windows Firewall, it's also highly recommended not to use Dynamic Port allocations but to define a static port for each instance.
Antivirus Exclusions
Target System
Exclude
Description
Windows Failover Cluster
Witness Drive
The witness disk is used for achieving quorum in your cluster.
C:\Windows\Cluster
The directory for your clustering binaries.
SQL Server Data files
MDF, NDF, LDF
The common file extensions used by SQL Server.
SQL Server Backup files
BAK, TRN
The common file extensions used by SQL server
SQL Server Trace files
TRC
BAK, TRN
SQL Server Log files
MSSQL\LOG directory
The directory for SQL Server log files.
SQL Server Executable
SQLServr.exe
SQL Server executable.
SQL Server Agent Executable
SQLAgent.exe
SQL Server Reporting Services Executable
ReportingServicesService.exe
SQL Server Analysis Service Executable
MSMDSrv.exe
