You can specify changes as a percentage, an increment, or as a final length or angle. LENGTHEN is an alternative to using TRIM or EXTEND.
Displays the length and, where applicable, the included angle of the object.
LENGTHEN does not affect closed objects. The extrusion direction of the selected object need not be parallel to the Z axis of the current user coordinate system (UCS).
Changes the length of an object by a specified increment, measure from the endpoint that is closest to the selection point. Delta also changes the angle of an arc by a specified increment, measured from the endpoint that is closest to the selection point. A positive value extends the object; a negative value trims it.
Delta Length
Changes the length of the object by the specified increment.
Angle
Changes the included angle of the selected arc by the specified angle.
Sets the length of an object by a specified percentage of its total length.
Sets the length of a selected object by specifying the total absolute length from the fixed endpoint. Total also sets the included angle of a selected arc by a specified total angle.
Total Length
Lengthens the object to the specified value from the endpoint that is closest to the selection point.
Angle
Sets the included angle of the selected arc.
Turns on Dynamic Dragging mode. You change the length of a selected object by dragging one of its endpoints. The other end remains fixed.
Powered by AutoCAD®
