Microvellum Foundation Library Release Notes | Build 21.0227
The following release notes apply to Microvellum Foundation Library, Build 21.0227
Additions:
  1. Added Master Split Cabinet.
  2. Added Master Split Corner Cabinet.
  3. Added more options to back overlay conditions.
  4. Added route as drawer bank to drawer cabinets.
  5. Added the Toe kick Assembly to the wizard.
Modifications:
  1. Removed file drawer prompts from local products. This will now be achieved by file drawer subassemblies.
  2. Linked the target spacing for screws, dowels and cams to the lookup tables in the globals.
Resolutions:
  1. Resolved an issue with back nailers, the length was incorrect when using Full Applied Backs.
  2. Resolved an issue with drawer front calculator when using overlay bottoms.
  3. Resolved an issue with local drawer slide selection not updating the wood Drawer box Subassembly.
  4. Resolved an issue with Blum Aventos HF lift creating an error "Part Name New Part is invalid. Cannot create machine code for this part."
  5. Resolved an issues with handle placements in 2D Elevation views.
  6. Resolved an issue with handles not turning off when using Shadow Lines.
  7. Resolved instances throughout the library where Toe Kick was spelled as one word.
  8. Resolved an issue where selecting Extend Toe Kick left or Extend Toe Kick Right in the local product was not updating the corresponding prompts in the kick subassemblies.
  9. Resolved hard-locked metric materials in the Unitless Material File.
  10. Resolved an issue with the Base, Tall and Upper Applied panels not drawing due to a name error.
  11. Resolved an issue with shelf holes locating in the wrong position when using the Wall Offset Right prompt in the Corner cabinets.
View Release Notes from the Previous Build
