Microvellum Foundation Library Release Notes | Build 21.0309
The following release notes apply to Microvellum Foundation Library, Build 21.0309
Additions:
  1. Added "LibraryName" prompt to all master cabinets.
  2. Added new options to the Toe kick assembly, and renamed existing options.
  3. Added Product "Transition Toe Kick Base."
  4. Added Product "Diagonal Toe Kick Base."
  5. Added Product "Corner Toe Kick Base."
  6. Added Product "Open Corner Toe Kick Base."
  7. Added Subassembly "Diagonal Toe Kick Assembly Box."
  8. Added Subassembly "Corner Toe Kick Assembly Box."
  9. Added Subassembly "Transition Toe Kick Assembly Box."
  10. Added Subassembly "Toe Kick Assembly Box."
  11. Added Subassembly "Open Corner Toe Kick Assembly Box."
  12. Added Subassembly "Open Corner Adjustable Legs."
Resolutions:
  1. Resolved an issue with Base Front Stretcher - HOLES3[Left Dowels] looking at custom spaced screws, not dowels.
  2. Resolved an issue with Corner Cabinets - Notched Back Left part location in Y origin when using the "Inset_Back_Left" prompt.
  3. Resolved an issue with the Fridge cabinet and the Master Enclosed Appliance Cabinet not drawing the applied ends.
  4. Resolved an issue with the door buffer location in Z origin being incorrect when using a negative bottom reveal with lift up doors.
  5. Resolved an issue with missing machining on Hafele press-in door buffers.
  6. Resolved an issue with Drawer systems runners looking at the Depth instead of the runner Length prompt.
  7. Corrected the Front Stabilizer position and hardware name on all Blum drawers.
Removals:
  1. Removed "Default File Drawer Box Depth" and "Default File Drawer Front Height" prompts from the globals as they are no longer referenced.
  2. Removed file drawer prompts from local products.  File drawers are selected from the drawer options list.
View Release Notes from the Previous Build
