Microvellum Foundation Library Release Notes | Build 21.0519
The following release notes apply to Microvellum Foundation Library, Build 21.0519
Additions:
  1. Added Washing machines to appliance folder.
  2. Added Dryers to Appliance folder.
  3. Added Rangehoods to appliance folder.
  4. Added use SAW for rebated thin backs.
  5. Added Shelf Standards.
  6. Added global to turn on wall hangers "G!Add_Wall_Hangers."
  7. Added missing prompt to Upper Corner Cabinets "Construction Method Thick Backs."
  8. Added top facias to corner cabinets.
  9. Added Border cut-out to glass panels in the MV Profile door for Shaped profiles.
  10. Added the ability to have different back construction for base, tall, and upper cabinets.
  11. Added Formula to ProductName prompt in Master Cabinets.
Modifications:
  1. Updated Set 2 sided materials to always flip by default.
  2. Door Type prompt in the MV Profile Door has been hidden, as it should not be changed.
  3. Updated Liftup systems, all hardware is now in the component doors subassembly instead of the individual face subassemblies.
  4. Rebuilt Blum Tandembox Antaro and Blum Tandembox Intevo.
  5. Rebuilt Grass DWD XP Drawer from new template.
  6. Rebuilt Grass Vionaro Drawer from new template.
  7. Rebuilt Hettich InnoTech Atira Drawer from new template.
Resolutions:
  1. Resolved machining issues with Hettich Suspension bracket SAH 116 S Left & Right.
  2. Resolved scaling issue with Hinge "BLUM Angled -30deg Full Overlay Inserta."
  3. Resolved an issue with the door bumps not associating with the door on angled cabinets.
  4. Resolved an issue with the bottom drawer z origin in the "Tall Pantry With Drawers."
  5. Resolved an issue when selecting a shaped shelf in bay 2 not adding the shaped cut-out.
  6. Resolved an issue with the blind panels in blind corner cabinets, creating unnecessary face 6 machining.
  7. Resolved an issue causing name errors with the shaped shelf cut-out in corner shelf fixed subassembly.
  8. Resolved an issue with Overlay tops and Bottoms in Corner Cabinets where the cut-outs were opposite.
  9. Resolved several scaling issues with the aluminum handles and Shadowline extrusions.
  10. Resolved an issue with the corner cabinet having the with and depth deferent as default.
  11. Resolved an issue with overlay top and bottoms in corner cabinets not being the correct with and length with using nailers and overlay backs at top or bottom.
  12. Resolved an issue with the finished faces subassembly when using glass door and right swing, the 2D elevation drawing for the cut-out was drawing off to the right of the door.
  13. Resolved an issue with the MV Profile Door subassembly when using a right swing, the 2D elevation drawing for the profiles were drawing off to the right of the door.
  14. Resolved an issue with the MV Profile subassembly, when selecting a glass cut-out. The rebates for the glass were getting turned on for all 8 panels as default.
  15. Resolved scaling issues with Blum Adventos lift hardware blocks.
  16. Resolved an issue with material thickness in the solid wood door subassembly.
  17. Resolved an issue with ADA Sinks referencing an old selection for notched toe kicks.
  18. Resolved an issue with the Cabinet Modification Chamfer Top subassembly the top chamfer panel was not considering the nailer thickness.
  19. Resolved an issue with the Cabinet Modification Chamfer Top and Bottom subassembly the top chamfer panel was not considering the nailer thickness.
  20. Fixed issue with the Cabinet Modification Chamfer Bottom subassembly, where the right-hand dado was machining incorrectly on the chamfer bottom.
  21. Resolved an issue with the Cabinet Modification Chamfer Top & Bottom subassembly, where the right-hand dado was machining incorrectly on the chamfer bottom.
  22. Resolved scaling issues with Salice hinge plates.
  23. Resolved several issues with the shadow rails in Blind Corner Cabinets.
  24. Resolved an issue with the countertop machining on Transition cabinets, the front machining was incorrect when using fillers.
