- Resolved an issue when using a router hinge cup hole radius was hard locked to metric.
- Resolved an issue with handles drawing on upper lift up cabinet when selecting none in the hardware wizard for handle type.
Resolved an issue with custom spacing on small parts for cams, dowels, and screws when using imperial.
Resolved an issue with the notches not machining in the rails from the drawer division when using any construction method other than Dado.
Resolved an issue with the angle cut-out on the front of angled corner cabinets, with the router lead not including the dado groove width.
Resolved an issue with the thickness Shelf looking at L!Inside_Width instead of Width.
Resolved an issue with cabinet referencing G!Door Gap instead of the local Door Gap.
Resolved an issue with the location of the second drawer when using a double top drawer with a single division.
Resolved an issue with the notched toe kick machining turning on when selecting notched toe kick in the global and the toe kick height was set to 0 or ProductCode set to upper.
Corrected help text on show material options prompt.
Corrected help text on show construction options prompt.
Resolved an issue with 2D Plan drawings for diagonal angle shelves.
Resolved an issue where drawer division dado for rear rail was not creating a notch in the top rail.
Resolved an issue with 2D drawings for drawer cabinets are using Handle Type instead of Drawer_Handle_Type.
