Microvellum Foundation Library Release Notes | Build 21.0630
The following release notes apply to Microvellum Foundation Library, Build 21.0630
Additions:
Added Accessories category to the library.
Added Inner Drawer with Shelves Above Subassembly insert.
Added knock-down fitting to the back of cabinets as an option.
Added global to control the door drawer stretcher on door drawer cabinets with options to only have a stretcher for double doors or double top drawers.
Added cut-out to the bottom to match the under-panel cut-out in the "Upper Undermount Rangehood”.
Added option to remove the back of the "Under Counter Oven Cabinet."
Added Cabinet Faces Only Product.
Resolutions:
Resolved an issue with the drawer rails sitting back the “Door_to_Cabinet_Gap” when using inset doors with inset drawer rails unticked.
Resolved a reference issue with finished faces subassembly when using buyout materials.
Resolved an issue with the Fridge cabinet not drawing the lift-up doors when selected.
Resolved an issue with the Shelf Standards routes always being turned on in the corner adj shelf on the right hand back.
Resolved an issue with the top and bottom edgeband on thick backs staying on when having captured back, top, or bottom.
Resolved an issue with the downlights being in the wrong Z origin in the "Under Panel Product" so they were not attaching to the panel.
Resolved missing Rear Construction Method prompt in the pigeon-hole subassembly.
