Microvellum Foundation Library Release Notes | Build 21.0723
The following release notes apply to Microvellum Foundation Library, Build 21.0723
Additions:
Added a range of Bar Stools to the Accessories folder.
Added some new plants to the Plants product in the Accessories folder.
Added images for the products in the Accessories folder.
Added filter to the wrapped battens so they will only turn on when rails are selected.
Added the ability to add shelves on both sides of the division in the "Division with Fixed Shelves" and "Division with Adj Shelves" subassembly inserts.
Added "Upper Sloped Top" Products to the Upper Cabinet Accessories Folder
Added Global to add edging to the tops and bottoms of sides "Base Bottom Edges Finished", "Base Top Edges Finished", "Tall Bottom Edges Finished", "Tall Top Edges Finished", "Upper Bottom Edges Finished", "Upper Top Edges Finished”.
Added When selecting "Bottom_Finished" or "Top_Finished", the 3d layer will change to a finished layer.
Added the option to specify width inside or outside for the Countertop With "Waterfall Ends". Specify inside makes it easier to pick points and place around cabinets.
Added "Any Angle Toe Kick Base" product.
Added System Prompt "WallOffset" to all relevant cabinets, and changed the current "Wall_Offset Prompt to "Cabinet_Void" in all relevant cabinets. This will allow the user to offset the cabinets from the wall without changing the depth of the cabinet when using "WallOffset. in comparison to offsetting the cabinet from the wall and changing the cabinet depth when using the "Cabinet_Void" Prompt.
Added "Any Angled Toe Kick Assembly Box" subassembly.
Added "Angled End Adjustable Legs" subassembly.
Added "Angled End Notched Toe Kick" subassembly.
Added front cam adjusters to wood drawer box.
Modifications:
Modified parameter 5 in the Dado tokens so that when G!Dado_Type="Lock Dado" the parameter is not left blank. It now will equal the "G!Dado_Groove_Width". This will allow the user to have a "G!Dado_Groove_Width" greater than the cutter width being used.
Updated the layer States in the Metric and Imperial drawing templates.
Resolutions:
Resolved an issue with the Finished faces subassembly, The hinge plate setback in the "LookupTableBayPositions" column 11 had "G!Door_to_Cabinet_Gap" inside the M2U function.
Resolved an issue with the "Suspension brackets subassembly". The hardware was getting offset by 0.1. This was too much for imperial and was causing the hardware to rotate 180. It has now been changed to 0.01.
Resolved an issue with the dado
machine token coming from the sides into overlay top and bottoms, it was
following the rules of the back machining.
Resolved an issue with the Scribe
Fillers with Cleats not drawing to the correct width when under minimum filler
width.
Resolved an issue with the edging on
tops and bottoms staying on carcass edge when selecting "Bottom
Finished" or "Top_Finished. It will now change to "Finish Top
Edges" or "Finish Bottom Edge”.
"Inner Drawer" subassembly where the drawer type prompts were hidden,
not allowing the user to select different drawer types for each drawer.
"Applied End" subassembly where the "Extend_Front" prompt
was not referenced in the Y origin causing the panels to be offset incorrectly
in the y origin.
Resolved an issue with parameter 5
of the Dado tokens not looking at the correct associated panel thickness for
the part when using G!Dado_Type="Regular Dado".
Resolved an issue with several products where the right sides had a machine point of 7M, this was causing the
machining for notched sides to be placed on the top of the panel.
Resolved an issue with the Z
placement of the hinge and hinge plate blocks in the cross-section drawings for
upper cabinets.
being applied to the back of sides when "Back_Finished" was selected
along with "Back Construction" having "Full Applied Back
selected.
Resolved an issue with the corner
adj shelf drilling not attaching to the backs when using thick backs and
G!Drill_Through_Back_for_Adj_Shelves" was unticked.
"G!Finished End Text Alignment" hard valued to 25.4.
Resolved an issue where the
"Drawer_Material" Prompt was not visible in door-Drawer Cabinets.
Resolved an issue with the Drawer
Stretcher staying on when using shadow line Finger Pulls.
"Component Drawers" subassembly, the drawers were out of position in
the Z when using shadow line Finger Pulls. It was not considering the
"Top_Reveal".
Continuous Shelf Holes not turning on in corner cabinets.
Resolved an issue with the Top Facia's where the z
origin was looking at G!Horizontal_Door_Gap instead of the top_reveal.
Removals:
Removed incorrect comments on hinge plates in the hardware file.
Removed unnecessary face 6 machining on corner cabinet backs coming from the front rails.
