Microvellum Foundation Library Release Notes | Build 21.0831
The following release notes apply to Microvellum Foundation Library, Build 21.0831.
Additions:
  1. Added rotated 2D Section drawings for Tab-pull handles on upper cabinets.
  2. Added the ability to turn off the Rail Notch locators in the "Division Insert" subassembly.
  3. Added the ability to change how far the rendering lights are positioned from the wall.
  4. Added global variable to change the Notched Toe Kick Position.
  5. Added material finish label options to the Wizard.
  6. Added back splashes to draw only countertops on standard cabinets
  7. Added Help text for G!Thick Backs Use Default Construction Method.
Resolutions:
  1. Resolved an issue with the right-hand cam token on the top and bottom of the corner cabinet, where the hole locations were referencing the G!LookupTableTargetSpacingDowels instead of the G!LookupTableTargetSpacingCams.
  2. Resolved an issue with the right-hand cam token on the Corner Shelf Fixed Subassembly, where the hole locations were referencing the G!LookupTableTargetSpacingDowels instead of the G!LookupTableTargetSpacingCams.
  3. Resolved an issue with the Invisible Fasteners being rotated incorrectly on the bottoms of thick backs.
  4. Resolved issues with overlapping prompts in subassembly inserts.
  5. Resolved an issue with the "Master Angle End Cabinet". The machining into the back from the bottom and top was not turning on.
  6. Resolved an issue with the "Grass Nova Pro Scala" drawer Front Fixing Bracket Type, changed from "Screw On" to "Screw-On" as the default.
  7. Resolved an issue with the Pigeonhole Subassembly - When having more than 3 divisions, the shelves did not have a notch for the divisions. The machine tokens had shifted one cell to the right. All machine tokens after the third notch were out of alignment.
  8. Resolved an issue with the "Hinge_Blum_Bi_Fold" or "Hinge_Blum_Bi_Fold_Inline" hardware. The machining tokens for the cup holes were looking at an old tool reference. also, there was machining left in the hardware for the plates. this now comes from individual mounting plates.
  9. Resolved an issue with insert with divisions not getting notched out at the top front of the divisions for "Wrapped Battens".
  10. Resolved an issue with the hinge location in the z origin when selecting extra hinges in the subassembly.
  11. Resolved an issue with the MV Profile Door, when changing the panel heights, the routes with perfect corners were looking at panel 1 height.
  12. Resolved several issues with the "Tall Pantry with Drawers" cabinet. It has been rebuilt from the "Master 2 Bay Vertical Cabinet".
  13. Resolved several issues with the shadow rail subassemblies.
  14. Resolved an issue with the base point and rotation of the right-hand side in several open cabinets.
  15. Resolved a scaling issue with the toilet in the accessories folder.
  16. Resolved an issue where the Suspension Bracket subassembly Offset Y was referencing an old global prompt
  17. Resolved an issue with the Component folding door subassembly where decreasing the left reveal Overhang caused the hinge plate to no longer be associated.
  18. Resolved an issue with the Fridge Cabinet missing the cabinet void prompt.
  19. Resolved an issue with the Pigeonhole Subassembly - When having more than 3 divisions, the shelves don’t have notch. The 3-sided machine token had shifted one column to the right leaving a blank column.
  20. Resolved an issue with the Shelf Adj subassembly in Blind corner Cabinets where the Shelf holes on the right did not allow for shaped shelf depth.
