Microvellum Foundation Library Release Notes | Build 21.1006
The following release notes apply to Microvellum Foundation Library, Build 21.1006.
Additions:
  1. Added mirror values to the applied panels and fillers for left and right prompts.
  2. Added Tall Wall Oven Full Box Cabinet.
  3. Added Tall Wall Oven with Microwave Full Box Cabinet.
  4. Added Tall Wall Oven Cabinet.
  5. Added "WallOffset" prompt image.
  6. Added Cabinet Connecting Holes (Sex Bolts) to all cabinets.
  7. Added buyout door and drawer box options to the project wizard.
  8. Added Countertop with Substrate.
  9. Added the ability to change the left and right-side material of all cabinets.
Modifications:
  1. Simplified thickness formulas in products for better stability.
Resolutions:
  1. Resolved an issue where the control type for the "Top_Continuous_Shelf_Holes" prompt was looking at the "Continuous_Shelf_Holes" prompt, so it was not visible when selecting adj shelves in the top component inserts.
  2. Resolved a scaling issue with the Blum tip-on door hardware.
  3. Resolved an issue with the applied ends still overhanging the front of the cabinet by the door thickness when selecting inset doors.
  4. Resolved an issue with the hinge plate not associating with the cabinet bottom when selecting inset doors.
  5. Resolved an issue with hard locked sizes to metric in the Cabinet Faces Only product.
  6. Resolved a block rotation issue with the 3D_Blum_Aventos_HK_Hinge Screw-On_Right.dwg. It was rotated 180 deg the wrong way.
  7. Resolved a scaling issue with the Blum Aventos HK - Lift Mechanism - Screw-On and the Blum Aventos HS - Lift Mechanism - Expando T DWGs.
  8. Resolved an issue with the Hafele Free Up lift systems the Y origin for the face drilling was not looking at the G!Door_To_Cabinet_Gap.
  9. Resolved machining issues attaching to the door face on the Grass Kinvaro T-Slim lift system. It was not looking at the door to cabinet gap.
  10. Resolved machining issues attaching to the door face on the Grass Kinvaro T-65 lift system. Y origins were reversed.
  11. Resolved machining issues attaching to the door face on the Grass Kinvaro T-57 lift system. X origin was out and also the drilling into the carcass side had a hard locked metric value in the end X.
  12. Resolved drilling issue with the RPC Institutional Overlay 376 the End Y needed to be a negative in the bore token.
  13. Resolved drilling issues with the Blum Aventos HK-Top lift system, the drilling was not coming out on the cabinet sides or the door face in the screw-on version.
  14. Resolved an issue where values in the Any Angle Toe Kick Base - Back Width Left/Right were hardcoded to metric values.
  15. Resolved an issue with the "Base Return Filler", "Tall Return Filler", "Upper Return Filler". When using a right filler and having the filler width under the "Minimum_Filler_Width", the dummy route was referencing the back of the part not the front so the 3d drawing was inaccurate.
  16. Resolved an issue with the Upper Corner Open Cabinet, the 2D cabinet drawing was opposite when changing the left and the right depth.
  17. Resolved an issue with the shadow rail finger pull prompt being hidden in the wall oven cabinets.
  18. Resolved an issue with the wall oven cabinet where the toe kick was not getting added to the z origin of the bay 3 carcass when it was the last bay.
  19. Resolved an issue where the drawer options were not showing in the Base 1 Drawer cabinet.
  20. Resolved an issue with the Invisible Fastener machining not offsetting on the shelf fixed subassembly when using shaped shelves left or right.
  21. Resolved an issue with the appliance shelf when using cams, they were on the top face of the shelf. Now they have been moved to the bottom face.
  22. Resolved an issue with the Toggle Bolt machining when selecting global "Hinge Cup Machining” to use Router. The X origin for the route hole token was set to 0 but should have been 35mm.
  23. Resolved an issue when Use Route for Hinge Cups was selected, the parameter for pocket had a formula in it causing the routes to be incorrect.  Needed to be set to a hard value of 1 to pocket.
  24. Resolved an issue when selecting finished bottom or top with overlay bottoms or tops, the layer was not changing to a finished layer.
  25. Resolved an issue with the Horizontal Opening Splitter calculator being blank.
