Microvellum Foundation Library Release Notes | Build 22.0114
The following release notes apply to Microvellum Foundation Library, Build 22.0114.
Additions:
  1. Added Gang Lock routes to all drawer bank cabinets.
  2. Added the ability to change the shelf hole qty per shelf in all adj shelf subassemblies.
  3. Added the ability to turn off the 2d plan tokens for inserts.
  4. Added more handles.
  5. Added the Richelieu Optimiz-R drawer system to the US drawer list.
  6. Added global variables for future face frame expansion.
Modifications:
  1. Updated the way the drawer boxes calculate. There are now prompts for the top and bottom gaps for each drawer as well as the available opening for the drawer.
Resolutions:
  1. Resolved an issue with the gang lock location having a name error and was putting the lock in the center of the drawer.
  2. Resolved an issue with the Blum bi-fold hinges causing an issue when using the global route hinge cups.
  3. Resolved an issue with the machining coming from the shadow rails on the right-hand side set to draw only.
  4. Resolved an issue with the dados on the drawer stretchers so that the notches are in line with the top stretcher
  5. Resolved an issue with the Fixed shelf subassembly where the dado token mortice was not looking at the width of the Tennon.
  6. Resolved an issue with the sink subassembly when using under-mount sinks. The Rim of the sinks was active with a cut-out the same size as the part. This was causing issues with AutoCAD ViewBase.
  7. Resolved an issue with the qty for finished face subassemblies in some products look at "No Doors" instead of "No Door".
  8. Resolved an issue with a double-up of prompts in the globals for the inset face’s gaps. All products are now looking at "G!Inset_Door_Drawer_Reveal" instead of "G!Door_Reveal_Inset_Door".
  9. Resolved an issue with a double-up of prompts in the globals for the face reveals. All products are now looking at "G!Default_Door_Drawer_Reveal" instead of "G!Door_Reveal".
  10. Resolved an issue with Front Stretcher where the Drill Rails for countertop fixing machine token. The start x and end x reference distance to the left and right edge where the distance between holes references distance to the front and back edge. This is now looking at the distance to left and right for the distance between holes.
  11. Resolved an issue with the 2D elevation drawings being placed in the incorrect placement in x in the Applied panels.
  12. Resolved an issue with the 1 Drawer Cabinet, where the prompts to change the drawer type were not visible.
  13. Resolved an issue when ticking on the edit materials prompt in the local products was causing a NA error in the Thickness_Door prompt in some cabinets.
  14. Resolved an issue with the "Front Fixing Bracket Type" Prompt in all drawer boxes being hidden.
  15. Resolved an issue with the Inotech Attira "Bottom_Length_Deduction" having the values incorrect.
  16. Resolved an issue with the inside height calculation looking at the stretcher thickness instead of the top thickness when using Overlay tops.
  17. Resolved an issue in the Toe Kick Assembly Box subassembly where the "Construction_Method” did not look at the local prompt.
  18. Resolved an issue with the wood drawer box referencing missing prompts when using the prompt "Raise_Sub_Front_On_Top_of_Bottom"
  19. Resolved an issue with the Shadow Rails Subassembly, when using the prompt "Shadow Line Offset" the cut-out in the sides was not offsetting.
