Additions:
- The Global Variable “Plan Finished End Text” was added to optionally add plan view text at each cabinet finished end condition. Enter zero or leave blank to disable.
- Improved the automatic “Drawer Spacer at Hinges” feature.
- Added global control with new variable "G!Drawer_Spacers_At_Hinges".
- Updated the two Inner Drawer subassemblies by adding Left_Drawer_Spacer, Right_Drawer_Spacer prompts, and moved the controlling logic there instead of the Prompt Value column. (Turning on left/right division will also disable the spacers.)
- A new hardware wizard variable “Default Drawer Spacer Height” was added to give users control of the spacer size (height).
- The Hardware Wizard variable “Dowel Fitting Wood Drawers” was added to give users the same control over drawer box dowels as with cabinet dowels.
- Imported Valance product from the legacy Component Cabinet library.
- Added “Diagnostic G Code Test Product” to assist with diagnosing g-code & machine connections.
Modifications:
- Dowel tokens were updated in Nailer parts to check if the width qualifies as a small part based on the “G!Dowel_Small_Part_Threshold” variable. This can change the dowel location/pattern used.
- Certain prompt variables that could controlled by both the parent product and the subassembly prompt have been adjusted to only allow changes from the parent. If you see a subassembly prompt, such as Adj Shelf Qty, greyed (dimmed out), these will need to be changed from the parent product cabinet.
- Hardware Array option for Lamello Cabineo will now default to face 5, not 6 for general cabinet parts like the bottom. This is now a variable controlled inside column 7 of H!LookUpTableEdgeArray
- Finished Top option will now turn off Countertop Fixing holes.
- The global variables listed below have been updated to now look to the hardware wizard for their values. This was done to match the cabinet dowel settings. Updated the 5mm Dowel row inside LookUpTableDowels. If you are running the update utility, please verify the values are still correct for your setup.
1. Drawer Box Dowel Edge Depth
2. Drawer Box Dowel Face Depth
3. Drawer Box Dowel Diameter
4. Drawer Box Dowel Edge Diameter
Resolutions:
- Resolved issues with the 2D plan and elevation views of countertops/benchtops in cabinet products. The overhang variables will now correctly reflect changes, including the back splash parts.
- 2D Elevation of corner cabinets will now show carcass parts at open conditions.
- An issue in the Vertical Splitter Subassembly that caused opening height problems in cabinet openings was resolved. The prompt "Position of Shelf" value should remain set to zero as default.
- An issue in Hettich Quadro V6 IW20 & Hettich Quadro V6 drawer slides was resolved. It will now calculate the correct drawer box depths.
- Blum Metabox drawer system will now include machining holes for the Soft Close feature.
- The Bullnose detail within Countertops/Benchtops will now correctly be displayed in 3D in Imperial.
- The Cabinet Modification Option, "Cabinet Notch Center", will now correctly pass the center distance to drawers when they are a nested subassembly.
- A Lock dowel rotation issue inside the Wood Drawer Box was resolved.
- An issue in the Cabinet Faces Only product that prevented the display of Door Type was resolved.
- The Component Doors subassembly now has the Add Lock prompt.
- Face Frame reports were updated to correctly display the part item# to match the Face Frame Rear picture.
- Face Frame Split Height Cabinets - Mid Stile chamfer tokens now only “on” when set to Haunched.
- Numerous other small issues that were reported by users have been resolved as well.
