Microvellum Foundation Library Release Notes | Build 23.0320
The following release notes apply to Microvellum Foundation Library, Build 23.0320.
This update includes many changes & additions to the Microvellum Closet/Wardrobe Expansion. If you have not purchased this expansion, you will not have access to these specialty products. Contact your account manager for more information.
Additions
  1. Added 266 additional Hettich Sensys hinges
  1. Added the new Blum MERIVOBOX drawer system
  1. Added two Kesseböhmer Waste bins.
  1. Added Hafele Ironfix Drawer Mounted Ironing Board.
  1. Added Strip Lighting Insert, including a new AutoCAD layer to drawing template: 3D_LED_LIGHT. This is tied to a material using the “Self-Illumination” option, creating a realistic glow in rendered scenes.
  1. Added the option to split drawers into two horizontal drawers for each inside the Component Drawer subassembly.
  2. *Added two new Closet Expansion products:
  1. Master Single Carcase Designer Closet
  1. Closet Aluminium Sliding Door Frame (with new Dias Sliding Door subassembly)
  1. *Added additional Closet Subassembly inserts:
  1. *Added two new “Face Options” to certain closet products:
  1. Folding Doors
  2. Sliding Doors
  1. *Added Base and Crown Moulding (Cornice) options to closet products. These can be found inside the advanced options tab.
  1. *Added Dynamic Part Names to match each closet Bay Opening. This will be useful for identifying individual parts and knowing which opening they belong to.
  1. *Added Shaped Front Shelves option for closet corner subassemblies.
  1. *Added the ability for L and U shape closet layouts to switch their overlay tops/bottoms to run full length of the width or the depth.
  1. *Added the ability for all closet products to have Finished Ends Left/Right. This will accommodate when a different material is desired at exposed finished ends.
  1. *Added full toe kick options to all closet products. This includes “Kick Face”, “Toe Kick Assembly Box”, “Adjustable Legs”, and “Notched Toe Kick”. These span the full width of the closet layout.
  1. *For multi bay closet products we added a prompt for each bay so users can change the bottom options within each individual bay.  Options are "No bottom", "Full Bottom" and "Full Bottom with Kick".
  1. *For multi bay closet products we needed the ability to have the base and top of each bay to line up with system 32 when changing the bay height. We have added prompts for each bay to calculate the bay height when using system 32. Each bay now has a "Required Bay Height" prompt. The user can enter the required height and the height of the bay will be calculated by the "Bay Height" which will calculate to the nearest derivative of 32mm.
  1. *Previously you could only change the height of the bays to be less than the closet height which would rase the bays off the floor for a wall hung closet. We now have  the ability to make the bay height greater than the closet height, which will increase the bay height above the closet height.
Modifications
  1. Modified the Drawer Options List. Waste Bins and Pull-Outs have been removed from the drawer options list and are now on their own individual lists. Five new rows have been added to the LookUpTableListOptions table inside the factory workbook. Additional options will be populated within these rows in future library updates.
  1. Waste Bin Pullout Options
  2. Base Pullout Options
  3. Pantry Pullout Options
  4. Blind Corner Pullout Options
  5. Corner Cabinet Pullout Options
  1. *Made improvements to Closet products’ prompts to prevent users from selecting items not possible (error trapping).
  2. *When changing Closet products to System 32, the default construction method will automatically be changed to Cams. Also, Cam Lock hole locations will use G!Front_Shelf_Hole_to_Edge instead of G!Cam_Distance_to_Front_Edge.
Resolutions
  1. Resolved issue in Work Order Summary report. Designer products will no longer show door swings for each bay.
  1. *Resolved issues with Closet products using system 32. Inserts will now properly line up with systems holes when changing the bottom options for each bay. Also have added prompts to calculate the positions and hole positions of parts within the subassemblies to line them up with the system holes of the partitions of the closet.
  1. Added missing N height dwg blocks for Blum LEGRABOX.
  1. Resolved issue in Drawer Stretcher subassembly that was causing inconsistent dado machining at the right side.
