Microvellum Foundation Library Release Notes | Build 23.0502
The following release notes apply to Microvellum Foundation Library,
Build 23.0502.
This update includes many new kitchen accessories & hardware
products that may not be available in every country or region.
Additions
- Added three new Hettich Veosys hinges
- Added the ability for separate Left/Right hand swing doors in Corner Cabinets
- Blind Corner Cabinet- Added Option to match the Blind Facia Panel to the Door Height
- Added feature to MV Profile Door to look at small pocket tool when the panel size is under a set size.
- Added a Universal Hardware Subassembly Insert. Also added additional hardware items that can be utilized by this new subassembly.
- Hook ceiling epco 301 2c
- Hook ives 201 double coat
- Hook ives coat & hat 571
- Grommet 3 hole mockett xg
- Pants Rack Left
- Pants Rack Right
- Trousers Holder
- Trousers Swivel Pull Out Left
- Trousers Swivel Pull Out Right
- Clothing Carrier 12 inch
- Clothing Carrier 16 inch
- Swinging Hanger
- Valet Rod Left
- Valet Rod Right
- Belt Rack 4 Peg 10 Inch
- Belt Rack 5 Peg 12 Inch
- Belt Rack 6 Hook 12 Inch
- Belt Rack 6 Peg 14 Inch
- Belt Rack 7 Peg 13 inch
- Belt Rack 7 Peg 16 Inch
- Belt Rack 10 Peg 19 Inch
- Tie Rack 12 Inch
- Tie Rack 19 Peg 20 inch
- Tie Rack 27 Peg 14 inch
- Closet 16mm Oval End Support
- Closet 19mm Oval End Support
- Closet 25mm Oval End Support
- Closet 25mm Round End Support
- Closet 35x15 Oval End Support
- Pole Cup Epco 850 1p0625
- Closet Rod Cup 32mm
- Closet Rod Full Cup 32mm
- Added/updated additional Appliance Products/Subassemblies including 309 new 3D & 2D elevation/section drawings. The below appliance categories have all been improved with a new structure that allows for brand name filters and regional availability considerations.
- Dishwashers
- Dryers
- Freestanding Ranges
- Fridges
- Microwaves
- Rangehoods
- Washing Machines
- Wall Oven
- Added Pullout options to all frameless Corner Cabinets, Blind Corner Cabinets, and Master Cabinet
- Added “Drawer Component Options” to frameless drawer cabinets that allows users to specify each drawer to alternatively be a Waste Bin Pullout or Base Pullout. These two new options will have their own list of options.
- Added five new cabinet products:
- Base Pullout
- Tall Pantry Pullout Cabinet
- Base 1 Drawer Waste Bin
- Base 2 Drawer Waste Bin
- Base 1 Drawer Waste Bin With Top Drawer
- Developed and added a number of new subassembly structures to accommodate additional cabinet inserts. These include new user definable LookUpTables to store each item’s technical details such as machining and 3D blocks for visual representation. The tables are also used to filter out regional and size limitations. 421 new CAD drawing blocks have been added to the Graphics\Hardware directory. See below for new items utilizing the new structure.
- Added a number of Kesseböhmer product lines
- Portero lift out baskets
- WASTEBIN pullout
- LeMans blind corner storage pullouts
- MagicCorner blind corner storage pullouts
- Added a number of Peka product lines
- Pinello Board Pullout
- Pinello Bread Pullout
- Pinello Cargo Pullout
- Pinello Internal 150mm Pullout
- Pinello Spice Pullout
- Pinello Towel Pullout
- Snello Pullout
- Pleno Plus Larder Pullout
- Pleno Standard Larder Pullout
- Added a number of Vauth Sagel product lines
- Corner Storage pull-outs
- COR Wheel 3-4
- COR Wheel Pro 3-4
- Blind Corner Storage pull-outs
- COR FOLD
- COR FOLD G
- COR FLEX
- CORNERSTONE MAXX
- Tall Cabinet pull-outs
- TAL Gate N
- TAL Larder
- TAL Gate
- Side mounted and front mounted base pull-outs
- SUB Side 90
- SUB Slim 90
- Added a number of Rev-A-Shelf product lines
- Base Pullouts
- Base Pullout With Knife Block & Utensil Bin
- Two-Tier Cookware Organizer
- 5349 Bottom Mounted Waste Bin
- Updated Salice Vibo Pullout Waste System (and others) to conform to new structure
- Added a 3D warning message “block” that will appear when user selects a pullout / waste bin insert that does not meet the minimum inside opening size. This block can be used to select the insert when opening the subassembly’s prompts UI.
Resolutions
- Resolved issue(s) with Frameless Drawer Bank Cabinets that affected the drawer front calculator and default drawer front heights.
- Added "N" to Number/Dimension in all prompts that are not dimension values as this was affecting certain results in reports.
- Resolved Corner Shelving Shaped Front issue when opening was too small
- Drawer option prompts will now show in Master Cabinet when drawers are selected
- Added Missing N Height Blocks for Blum LEGRABOX drawer system
- Applied End Products are now looking to the correct default door wizard variables (Base/Tall/Upper)
- Resolved issue with Door Buffer locations when using aluminium handles
- Resolved misspelling of Pantry Pullout in Global variables file
- "Drawer Handle Type" prompt in Door/Drawer Cabinets will now always be visible when top drawer is present.
