Microvellum Foundation Library Release Notes | Build 24.0221
Additions
  1. Added “Lookup” Option for all Fixed and Adjustable Shelf Quantity variables. Rather than entering a number for base/tall/upper shelf quantity, we now have an option called “Lookup”. When choosing “Lookup” from the dropdown, the shelf quantity becomes dynamic and uses "G!Max_Shelf_Spacing" variable to round down the available space to calculate the shelf qty. You can also override it at the product/subassembly.
  1. Base Applied Panel product - Added "Applied_End_to_Floor" as a local prompt, can now untick in the product to use the toe kick height when the global “G!Applied_Ends_to_Floor” is ticked. Also added a filter to the Bottom_Reveal so that it will only populate from the local product if the reveal is a negative value.
  1. Added Titus System 3 Cam option.
  1. Added new global variable “Component Setback” and linked to all products.
  1. Added new option to angled corner cabinet products: “Miter Side Front Edges”. All tops and bottoms have been updated with a draw only tokens and machine only tokens for the front route.
  1. Added “Master Corner Vertical Designer Cabinet”.
  1. Added new Removable Sub Top cabinet modifier subassembly. This insert will automatically cut an opening in the cabinet top, add lighting, and add a removable panel. Option to center the downlights in opening or to the doors.
  1. Added “Peka Shoe Pullout” to the Closet expansion.
  1. Added Grass Vionaro V8 system Drawer.
  1. Added Richelieu Undermount Soft-Close Drawer Slides 815 EVOLUTION, 825, & 823.
  1. Added additional Richelieu Axial drawer sizes 250 & 600mm.
  1. Added Richelieu Front Locking Devices 825 & 828 for narrow drawers.
  1. Added Peka Shoe Pullout option to the Closet Component Insert Options.
  1. Added additional options to the Shoe Shelf subassembly:
    1. Cam option
    2. Cam rear only
    3. Fixed Shelves
  1. Added four additional global variables to provide further control over which tools are to be used for thick back dado machining:
    1. Tenon Tool Thick Back
    2. Dado Tool Thick Back
    3. Dado Groove Width Thick Back
    4. Dado Depth Thick Back
  1. Added front cutout options to wooden drawer boxes (Rollouts). "Scoop" and "Angled" are included with variables for cutout size and radius options.
  1. Added a new global variable “Inset Door Setback” to allow inset doors to be set a specific distance in Y. Entering a negative value will trigger a special “simple” face frame option to appear in the Master Cabinet product. This option can be utilized to achieve a “face frame look” with a frameless cabinet carcass.
Modifications
  1. Modified the global variable “Dowel Distance to Front Edge”. For new library installs, will now default to 51mm for US Region.
  1. Modified the global variable “Dowel Target Spacing”. For new library installs, will now default to 96mm for US Region.
  1. Modified the Project Wizard variable “Default Construction Method”. For new library installs, will now default to “Dowel” for US Region.
  1. Modified the Project Wizard variable “Toe Kick Assembly”. For new library installs, will now default to “Notched Toe Kick” for US Region.
  1. Door Reveals will no longer reference "G!Inset_Door_Drawer_Reveal" when a cabinet filler or applied end is added.
Resolutions General
  1. Resolved issues with the Pricing Cost Based Estimating Product.
  1. Resolved issues within the Box End product.
  1. Resolved issue with Shadow Rails inside Horizontal Designer cabinets.
  1. Resolved issue when using Valance option with Vertical Designer upper cabinets. Hinge locations for upper openings will no longer incorrectly shift with a bottom valance.
  1. Shelf pin hardware quantity now correct when third row of holes are added due to increased shelf depth.
  1. Resolved issue in Upper Cabinets when "G!Applied_Ends_to_Floor" is turned on. The bottom reveal will now stay the same. There is a prompt in the subassembly that can be ticked if you require the upper applied ends to go to the floor.
  1. Resolved issue with Base Under Counter Oven product involving the Facia Height variable.
  1. Resolved issue with “Base Applied Panel” when using "G!Applied_Ends_To_Floor" option. Added "Applied_End_to_Floor" as a local prompt. Can now untick in the product to use the toe kick height when the global "G!Applied_Ends_to_Floor" is ticked. Also added a filter to the Bottom_Reveal so that it will only populate from the local product if the reveal is a negative value.
  1. Resolved issue with MV Profile Door subassembly. Updated the Offsetpolylines for the outer edges to resolve a problem when using the corner radius variable.
  1. Resolved Circular Reference Issue in Solid Wood Doors. Updated D!LookUpTableDoorProfilesInside column 30.
  1. Resolved edgebanding problem in “Shelves with Shelf Std” product.
  1. Resolved issues within the Shoe Shelf subassembly.
  1. Reviewed Appliance products and ensured all have associated 2D plan and elevation drawings.
  1. Resolved issues with Blum Merivobox Drawer height E Pure and F height.
  1. Resolved issue with the perfect grain prompt formula inside the Finished Faces subassembly. Will now properly reference drawer front material when it’s a drawer front.
  1. Resolved issue with the face frame cabinet plan view dimensions.
  1. Resolved issue with the "Drawer Bank" option in drawer bank cabinets.
  1. Resolved issue inside the Face Frame subassembly. Some variables were incorrectly referencing “L!” variable instead of it’s own local variable ("L!Right_Stile_Scribe_Amount").
  1. Face Frame attachment options have been added to the Drawer Stretchers in all drawer and door cabinets and drawer cabinets. It has also been added to the Drawer Stretchers in the Component Drawers FF and Component Door Drawer FF. Prompts were added to the Drawer Stretcher subassembly to turn on the face frame attachment options.
To download this build, visit the Foundation Library Downloads page.
