Microvellum Foundation Library Release Notes | Build 24.0322
Additions
  1. Added the Master Angled Ends Cabinet.
  1. Added a Global prompt, "Hinge Plate Offset From Front" for easier control.
  1. Added “Double Division” option to Horizontal Designer Cabinets, 3 Door Cabinets, and other similar products.
  1. Added a new feature to the MV Profile Door (MDF Doors) subassembly. When selecting “Grooved Panel”, one can now optionally select “Equal Spaced Grooves”. This will act as a “target spacing”, keeping all the grooves equally spaced instead of fixed distances that go outward from the center. New Door Wizard variable added “Equal Spaced Grooves” that can be used to select this on/off by default.
  1. Added an optional second and third row of set screw holes within the Wood Drawer Box subassembly. Formulas will automatically add the additional holes as required, but user can specify with the new prompt variable “Drawer_Front_Set_Screw_Hole_Qty”.
Modifications
  1. Modified the Nikpol Dragon Pro drawer system to match its supplier’s changes.
  1. "E!Drawer_Front_Edge" edging has been added to the backing rail parts in the Shadowline feature.
  1. Pie Cut Corner Cabinets- When the carcass radius is set to zero, the shelves will now also become zero. The "Shelf Setback" variable will no longer be included.
  1. Updated several drawer systems to prevent face 6 machining when the "Back Over Bottom" option is selected.
  1. The material pointer "M!Drawer_Box_Side" has been replaced with "M!Drawer_Wood_Spacer" to avoid confusion with “M!Drawer_Box_Wood_Sides”. Note that if you are running the Library Update utility, the new material pointer "M!Drawer_Wood_Spacer” will need to be pointed to your desired material.
  1. Modified default dowel and cam positions for small parts like nailers, toe kicks, and stretchers to avoid collisions.
  1. Modified the LEGRABOX drawer subassembly. All pocket cutouts for the drawer box bottom are now coming from a 4-sided cutout instead of phantom parts with dado tokens. This was changed to resolve potential machining issues with Toolbox. Other drawer systems to follow soon.
Resolutions General
  1. Resolved an issue with Wood Drawer Box subassembly. Added "Construction Method Into Bottom" so user can turn off dowels going into bottom when using "Raise Front/Back on top of Bottom".
  1. Resolved an Imperial/Metric conversion issue in Lamello Cabineo drill diameter machining (only affected imperial users). *
  1. Product Detail Reports styles 1-3 are now using the MVValueFormat for the Part Length and width. This affects the rounding of the displayed values. *
  1. Resolved an issue with Hettich AvanTech inner drawer system. Updated molding drawing for steel backs.
  1. Resolved an issue with the Room Component Wall product. All windows and door styles should now come in correctly.*
  1. When using the global “Drill Through At Divisions”, holes will no longer be missing in one opening. Also, when removing shelves from either the left or right openings, the holes will no longer be absent. This only applies to the Component Insert “Divisions With Adj Shelves”.
  1. Resolved an issue inside the Sink subassembly that sometimes caused issues with the AutoCAD Viewbase feature.
  1. Resolved a drill machining issue with Titus Tekform Slimline drawer system.
  1. Resolved an issue with Hettich hinge plate machining. Drill depth was not converting to imperial when required.*
  1. Resolved an issue that occurred when using the Shadowline Rail feature in certain products like Tall Wall Oven With Microwave. Added prompt "Top_Shadow_Rail_3_Sided_Cutout" to control when the top cutout is a 3-sided cutout vs regular corner notch.
  1. Resolved a part size issue with Cabinet Modification Option “Chamfer Top/Bottom” when using Full Applied backs.
  1. Resolved an issue with Wood Drawer Box subassembly when it’s an inner drawer (rollout). Set screw holes will now be disabled.
  1. Resolved an issue with Samson Fennel Legs. Middle back leg will now be orientated correctly.
  1. Added the“Buyout File Drawers” to the global variables and project wizard. This was a missing legacy option that the Wood Drawer Box was referring to.
  1. Resolved an issue with Corner Cabinets and their adjustable legs. Locations now correct when selecting finished ends.
  1. All "Base Handle Distance From Top" and "Upper Handle Distance From Bottom" variables have been updated in all products to look directly at their corresponding global variables.
  1. Added Dado and Hardware Array tokens to the Carcase subassembly. This is used for the Master Multi Carcase Designer FF cabinet.
  1. Added the prompt "Carcase Width" to all face frame cabinets. This can be used for reporting.
  1. Resolved an issue with “Extend Bottom Rail to Floor” feature.
  1. Resolved an issue with Face Frame Quarter Cabinets. Doors now sized correctly in imperial.
  1. Resolved an issue that affected Horizontal Designer FF cabinets when using Left/Right Overlay Control set to “Outside” AND side face frames/applied panels. Internal openings sizes will now calculate correctly and prevent issues with internal shelves being sized incorrectly.
  1. Related to this, inconsistencies between the designer cabinets and the regular framed cabinets have also been addressed. Applied FE panels will now be located in the same X location. It is recommended one review their project details if updating to this build.
Additions/Resolutions Closet/Wardrobe
  1. Resolved a part size issue with Closet/Wardrobe fillers & applied end panels at conditions when the bay height is smaller than the product height.
  1. Resolved an issue with Full Captured Back construction.
To download this build, visit the Foundation Library Downloads Page.
