Microvellum Foundation Library Release Notes | Build 24.0520
Additions
  1. Added a new product, the “Extruded Master Countertop”. Four other extruded countertop products have been replaced with a new version based on this product. Many new features have been added into this enhanced extruded product (Toolbox 24.1.0416 or newer required for some new features):
    1. Connector hardware (toggle bolts) available.
    2. Buildup options.
    3. Backsplash options.
    4. Offset from Polyline variable.
    5. Position of product Left or Right of line.
    6. Countertop front edge detail options.
    7. Supports recalculation of geometry with product prompt depth changes (without the need to extrude from polyline again).
    8. Supports additional more complex polylines such as non-blended radius conditions.
    9. More features planned for future enhancements.
  1. Added Galvin Prime Slim Drawers. (No Graphics) (AU/NZ Market only)
  1. Added Furnware Group SYMETRA Drawers. (No Graphics) (AU/NZ Market only)
  1. Added slot cutouts for aluminum file bars in wood drawers.
  1. Added the ability to associate drilling screw holes to thin backs as well as thick backs. New global variable added “Screw Construction Regular Backs”.
  1. Added a new global variable “Door Rounding” used with a FLOOR function to round down the width and height of all door & drawer front parts.
  1. Grain Direction & Perfect Grain Container prompts have been added to the MV Profile Door and the Solid Wood Door subassemblies.
  1. Added new features to the ADA Sink Angled Frame product:
    1. Angled Frame with Toe Kick.
    2. Inset or Overlay Angled Panel.
    3. Finished Front, Finished Sub Front, or Sub Front.
    4. Added horizontal parts to create an optional enclosed bottom.
    5. Inside and outside radius parameters for the angled polyline cut.
    6. Prompt layout has been changed and will most likely continue to be refined in the next update as we gather additional feedback.
Modifications
  1. Modified the rear notch on the Front Stretchers to match the Rear Stretchers. The notch will now look at "G!Dado_Small_Part_Notch_Distance_To_Rear_Edge".
  1. Replaced many M2U functions throughout the library with UCN to prevent undesirable default imperial values from appearing. For example, instead of “=M2U(1,Accuracy)" which results in “0.03937” inches, we now use “=UCN(0.0312,1)” or “=UCN(0.0625,1)” which provides fractional values (1/32” or 1/16”) more commonly used by imperial users.
These changes will not affect metric users. However, for imperial users, some default variables might change slightly in new library installs. M2U values that match specific hardware specifications have not been changed.*
  1. Changed how the globals “Back Width Adjustment” & “Back Height Adjustment” behave when they are both used together with Full Applied backs. The back sizes will adjust, however the X & Z origins will remain flush with the left side and bottom of cabinet. This will prevent any associative screw hole machining issues.
  1. All drawers updated to use "G!Drawer_Bottom_Hole_Depth" for the Bottom Hole Depth instead of a fixed value.
  1. Wood Drawers now use "G!Drawer_Box_Dowel_Target_Spacing" instead of "VLOOKUP(PARTMACHINEY(),G!LookupTableTargetSpacingDowels,2,TRUE)"
  1. Default value for "G!Drawer_Box_Dowel_Target_Spacing" changed to "UCN(3.7795,96)"
  1. For Solid Wood Drawer fronts, Stiles and Rails will now be the same width by default.*
Resolutions General
  1. Resolved the Solid Wood Door "Add Finish Label" prompt to match Finished Faces subassembly. The prompt will now correctly display one label per product when global “Finish Label Condition” = “Product”.
  1. Resolved an issue with all Finished Face/MV Profile Door/Solid Wood Door subassemblies referencing an incorrect column in the Door Wizard "D!LookUpTableDoorStyle" table. Various parameters such as “Default Top Rail Width” will now correctly reference the Door columns when it’s a door and the Drawer columns when it’s a drawer front.*
  1. Resolved an issue with the Hettich WingLine Guide hardware graphics. Should no longer cause issues with the Flatshot feature.
  1. Added a 140mm option to the Hafele Alto drawer system for the NZ region.
  1. Resolved a Hinge Plate issue for right hand doors in corner diagonal cabinets.
  1. Resolved an issue with Base Under Counter Oven product that was affecting the bottom Facia.
  1. For Solid Wood Drawer fronts, corrected "Use Single Solid Wood Front SA" so it will not reference the Min Door Height (column 13) when it's a drawer front.
  1. Resolved an issue in certain subassembly insert components that were incorrectly displaying Fixed Shelf Qty prompts when bay 2 was set to Adj Shelf.
  1. Resolved a machining issue in all Corner Cabinet’s right-side backs. Dado tokens were missing a value for parameter 5 Dado Thickness. This seemed to only affect users using a Saw.
  1. Resolved an issue when using Buyout Doors. Default buyout material used is no longer zero thickness.
  1. Added the option for Interior Components to reference Frame Opening vs Box Opening. When selected, certain interior inserts will reference the Face Frame Opening Height instead of the Interior Cabinet Height, allowing them to be centered in the frame opening.
Resolutions Office Furniture
  1. Resolved an issue within some Office Drawer Cabinets.
To download this build, visit the Foundation Library Downloads Page.
