Microvellum Foundation Library Release Notes | Build 24.0607
Additions
  1. Added additional features to the ADA Sink Angled Frame:
    1. Option to turn on Mounting Rails for the Angled Panel (and toe kick). Fastening method have been included.
    2. Hardware options have been modified to include fastening hardware to attach the angled panel to either a side or mount to a rail.
    3. Hardware position control prompts for the new hardware have been added for (X,Y) position along with lift off clearance.
    4. LookUpTableHorizontalMountHwr added to easily include user added hardware that will update the dropdown list of hardware and modify control values.
    5. Angled_Panel_Bottom_Reveal now works correctly and defaults to 0 for a flush Angled Panel to the edge of the carcass.
  1. Added additional hardware mounting options to the ADA Sink Angled Frame:
    1. Side Mounts: 
      1. Keku EH Suspension Fitting 
      2. Keku EHS Suspension Fitting 
      3. Button-fix type 2 
      4. SH 325 Zero Side Mount 
  1. Rail Mounts:
    1. Button-fix type 1 
    2. Button-fix type 3 
    3. SH 227 Galaxy 
    4. SH 350 Lock 
    5. SH 400 NZ Clip 
  1. Added additional functionality for grain matching products and door/drawer fronts together:
    1. Setting product item numbers to a value over 100 will trigger a new feature where the system will create perfect grain containers grouping doors & drawer fronts with matching item numbers (101.1, 101.2, 101.3).
    2. 2D elevation tokens added to help identify the grouping of perfect grain containers.
    3. New global variables added:
      1. "Split Drawers From Doors"
      2. "Split Double Width Cabinets"
      3. "Allow Grain Matching Across Multiple Products"
      4. "Show Perfect Grain ID on Elevation"
  1. Added additional global variables to control the Item Number positions for Counter Top and Toe Kick products:
    1. "Countertop ItemNumberX2DElv"
    2. "Countertop ItemNumberZ2DElv"
    3. "Countertop ItemNumberX3D"
    4. "Countertop ItemNumberY3D"
    5. "Countertop ItemNumberZ3D"
    6. "Toe Kick ItemNumberX2DElv"
    7. "Toe Kick ItemNumberZ2DElv"
    8. "Toe Kick ItemNumberX3D"
    9. "Toe Kick ItemNumberY3D"
    10. "Toe Kick ItemNumberZ3D"
  1. Added additional Blum Aventos HK Top options for “Chipboard Screw” machining.
  1. Within the Toe Kick Base product, screw construction has been added to the top of the sleepers into the cleats as well as machining from the front and back of the cleats into the front and back rails. We have also added in the"G!Dado_Minimum_Width" variable to add DADOs.
  1. Added a new report “Product Detail Report w Bays”. This report will display more information typically needed for designer cabinets with multiple bays.
  1. Added the ability to drop cabinet backs to the floor (when not captured). Added new global variable "G!Extend_Backs_To_Floor".
  1. Added prompts to the Tall Pullout Pantry. When selecting Horizontal Handles you now have the option to have centered Horizontal Handles. When unselecting Horizontal Handles you now have an option to have the handle on the left or right side of the face panel.
  1. Added help text warning messages for Base 1 Drawer Waste Bin product (and others). If the cabinet's inside width, height, or depth does not accommodate the correct size for the selected Pullout, the message will appear on the 2D plan view of the product.
Modifications
  1. Modified all appliance products to better differentiate appliance opening size vs actual appliance size. For example, a dishwasher may require 24” opening, but the appliance is actually 23.875”.
  1. Improvements made to the Door and Drawer Front Fabrication report. Door Styles will now display. Also removed subassemblies that were not actually doors from appearing.
  1. Magic Corner hardware for blind corner cabinets renamed to Magic Corner II to match manufacture’s specs.
  1. Extruded Countertop – The HeightAboveFloor formula has been updated to align with the standard Base Cabinet height.
Resolutions General
  1. Resolved an issue with many drawer systems’ drawer bottom part sizes when using “Back Over Bottom” option. Recommend verifying your particular drawer system drawer depths are matching your expected sizes. Also verify the “Back Over Bottom” selection is set to your desired option.
  1. Resolved a formula issue inside Base 1 Door Sink With False Front that was introduced in the previous update. Finished Faces will now display correctly.
  1. Resolved numerous hardware graphics issues wherein the graphics were not scaling properly for imperial scale users.
  1. Resolved a 2D elevation issue with Countertop With Waterfall Ends product.
  1. Resolved an issue with the rotation of the handle on the 2d elevation drawing for the left bi-fold doors.
  1. Resolved an issue when using Tall Wall Oven with Shadowline.
  1. “Adj/Fixed Shelf Qty” prompts will now remain visible when using “Division with Adj Shelves”.
  1. Resolved an issue when using Blum HF lift up hardware within Wall Oven cabinets. The calculation for the position of the lift mech in the component doors sub has been updated to look at the opening size, not the size of the overall cabinet.
  1. Resolved a Z location issue for certain drawer types inside the Component Drawers subassembly.
  1. Resolved an issue with “Base 1 Drawer Waste Bin” products where waste bin pullout types in the subassembly were not automatically being set when product is added.
  1. Resolved an issue in “Upper Open End Cabinet”.  Adj shelf holes will now line up when selecting Right Hand option.
  1. Resolved an issue with “Scribe Filler With Cleats” option when using different thickness material for the fillers.
  1. Global variable “Draw Hardware Blocks For Pullouts” will no longer control wood drawers. They will use “Draw Hardware Blocks For Slides”.
  1. Resolved an issue where extra AutoCAD scales were being added to the drawing whenever a dwg block (such as hardware) was brought in from a product. All dwg blocks have been purged of unnecessary scales.*
Additions/Resolutions Face Frame Cabinetry*
  1. Resolved a cabinet issue with the internal height calculation when using the “Add Center Shelf” option. This was introduced from the previous update and has now been corrected.
  1. Resolved an issue when selecting a cabinet Finished End and also Applied End on the same side. Parts will no longer be in the same space.
  1. Resolved an issue with door heights when selecting Top Facia and deselecting Intermediate Rails.
  1. Resolved issues with Base Transition Angle Cabinet FF. Product has been rebuilt from Master Transition Angle Cabinet FF.
Additions/Resolutions Office Furniture Expansion*
  1. Added the Office Desk - 1 Piece Top and Office Desk - 2 Piece Top products each with a shaped cutout in the corner and a bow shape on the front.
  1. Added the 3-piece Top Desk product with a corner leg configuration.
  1. Added scallop cutout options to desks and worktops used for back edge cable management.
  1. Added Cabinet Connector Holes option to all office furniture cabinet products.
  1. Simplified the office furniture cabinet products that were using two back parts used to transpose the part orientations and grain directions. This can now be done within the MV processing stations, so the extra parts were removed.
  1. Corrected a part thickness issue inside Standard Hob.
Additions/Resolutions Closet/Wardrobe Expansion
  1. Resolved an issue with Closet Drawers with Single Hanging product. Top Fixed Shelf will now be in the correct location when activated.
To download this build, visit the Foundation Library Downloads Page.
