The following release notes apply to Microvellum Foundation Library, Build 24.0624
Additions
- Added additional sample Generic Five Piece solid wood door styles:
- Raised Panel 5pc with Applied Molding
- Mitered Solid Raised Panel 5pc
- Mitered Haunched Solid Raised Panel 5pc
- Mitered with Applied Molding Raised Panel 5pc
- Mitered Inset Panel 5pc
- Mitered Inset Beaded Panel 5pc
- Plank
- Plank w Slab Molding
- Added legacy “Cal Door” Door Library with 49 different Door Styles and Four Door Types (new Door Wizard)*:
- Cal Door Mitered Solid
- Cal Door Mitered Inset
- Cal Door Cope N Stick Solid
- Cal Door Cope N Stick Inset
- Added Blum 95 deg Overlay Blind Corner Hinges
- Added 64 & 167 heights to the Hafele Alto Slim
- Added a “Post Laminate” option to the Extruded Countertop Products
- Modified the Access Panel subassembly insert. Added a visible prompt to control the lip thickness.
- Added enhancements & features to the Extruded Die Wall products:
- Extruded Die Walls will now perform better when extruding along a polyline a with non-blended radius.
- Extruded Die Wall products along a blended radius can now be segmented via the prompts
- Added “Bay Position” hidden prompt to all drawer subassemblies. This can be used in reporting to designate which drawer it is for assembly. Bay Position comment added to all drawer bottoms and wood drawer sub front parts.
- Added nine new global variables to better control which Nailers the user requires:
- "Use Top Nailer Base"
- "Use Center Nailer Base"
- "Use Bottom Nailer Base"
- "Use Top Nailer Tall"
- "Use Center Nailer Tall"
- "Use Bottom Nailer Tall"
- "Use Top Nailer Upper"
- "Use Center Nailer Upper"
- "Use Bottom Nailer Upper"
- Added new global variable to control whether Hardware is included within the Flatshot dynamic product image feature.
- "Flatshot Hardware"
Resolutions General
- Restored the "Slab Molding" feature within the Solid Wood Door subassembly. Added missing molding profile drawings.
- Resolved graphical rotation issues with Tab Pulls that affected 2D elevation and section views.
- Resolved an issue with handle location when using a top shadowline only with a drawer bank cabinet.
- Resolved an issue with toe kick assembly option in Any Angle cabinets.
- The Base 2 Bay Drawer has been rebuilt from the Master 2 Bay Horizontal Cabinet to resolve some issues with the shadowline feature.
- Resolved an issue in corner cabinets when using shelf standards.
- Resolved an issue when using the global variable “Extend Sides to Floor”. This will no longer affect Upper cabinets.
- Selecting the global “Face Frame Miter FE Joint” will now force the Applied Panel FF to ignore "G!Face_Frame_Outside_Overlay_at_FE" and align with the mitered face frame.
- Resolved a 2D plan view draw token issue for Transition Angle Cabinet FF products.
- Resolved an issue with Horizontal Opening Splitter FF when adding Shelf ADJ to a bay.
- The back in all Face Frame Cabinets will now be placed correctly in the Z origin and size correctly when selecting no bottom.
