Microvellum Foundation Library Release Notes | Build 24.0722
Additions
  1. Added five new Fulterer Drawer Slide/Runners:
    1. Fulterer 5045
    2. Fulterer 5210
    3. Fulterer 5000
    4. Fulterer 5001ECD
    5. Fulterer 5210ECD
  2. Added the Blum AVENTOS HKi lift system.
  3. Added features/revamped the Extruded Toe Kick Base product to have same features as extruded countertops. Added stacked skins feature on curved segments.
  4. Added features/revamped the Extruded Part Collection product to have same features as extruded countertops.
  5. Added Accuride 1532 Pocket Door hardware to the Component Pocket Doors subassembly.
  6. Added new global variable "Add Bottom Return To Wall Filler". Tick to add a bottom return panel to scribe fillers when attached to wall cabinets. The filler return bottom and top will now offset the valance distance when the Local Prompts "Left_Side_Full_Height" or "Right_Side_Full_Height" are unticked. When this new global is unticked, the "Left/Right Side Full Height" will uncheck to allow applied under panels.
  7. Added the Hafele Symo 3000 locks.
  8. Added a set of “Generic” hardware items for Hinges, Hinge Plates, Face Frame Hinges, and Adjustable Legs. These are non-brand specific and utilize simplified 3D graphics which improves MV performance when drawing products in a large drawing. These will be set as default for new library installs.
  9. Added Salice Conecta hinges for 1” (25mm) thick full overlay doors.
  10. Added 3 new global variables for better control within the Screw/Dowel/Cam construction tokens. For example, these will provide better results right out of the box when adding screws to nailers:
    1. "Screw_Offset_Small_Parts"
    2. "Dowel_Offset_Small_Parts"
    3. "Cam_Offset_Small_Parts"
  11. Added a new cabinet Back Construction option “Removable”. Added new global variable “Removable Back Clearance”.
  12. Added new rendered product images for Extruded Die Wall products.
  13. Added IFERROR to perfect grain override formula to prevent errors in the event a formula material has an error in its name.
  14. Added "Blind Panel Type" and "Blind Panel Style" prompts to blind corner cabinets, giving local control.
Resolutions General
  1. Resolved an issue with Hettich Avantech YOU rear fixing brackets.
  2. Resolved an issue with Carcase subassembly backs in Tall Wall Oven.
  3. Resolved an issue within the Master Die Wall extruded product. Skin parts will locate correctly when quantity is greater than 1.
  4. Resolved an issue in appliance products that caused the “Show Item Number” prompt to misbehave.
  5. Resolved an issue in Master Split Cabinet. "Lower Back" will now be in the correct location when using “Extend Back to Floor” global variable.
  6. Resolved an issue in all Frame and Frameless Transition cabinets when selecting “Adjusted Depth” option. "Cabinet Angle" will now calculate correctly.
  7. Resolved an issue with drawer front adjuster feature. Associative 5mm drilled holes will now appear correctly in the drawer box sub fronts.
  8. When "Default Construction Method FE" is set to “None” and "Construction Method Nailers" is set to “Screw”, the nailers will no longer switch to dowels at the Finished End.
  9. Resolved an issue with global variable “Extend Sides to Floor Global” affecting the Carcase subassembly in the Tall Wall Oven Full Box product.
  10. Resolved an issue in Extruded Die Wall w/ Skins. Angled studs now correct size when Inside and Outside skins are different thicknesses.
  11. Resolved issues with the Washing Machine and Dryer dwg blocks. Removed underlying entities that were causing issues when exporting to IGES.
  12. Resolved issue with the Internal Insert Peka Pinello Board Pullout. Changing to left hand will now have the correct associative drilling.
  13. Resolved two issues when using Aluminium Handles at drawers.
  14. Edgebanding at top edge will now be removed based on the Remove Edgetape column in "D!LookupTableAluminiumHandles".
  15. Drawer system heights will now calculate correctly by including the height of the Aluminium Handle as well as the drawer front height.
  16. Resolved an issue with "Shelf Edge" feature on Fixed and Adjustable shelves. When using "Lip Up" or "Lip Down", the machining extra machining will no longer appear.
  17. Resolved an issue with filler machining routes when cabinet top or bottom has a different material thickness than the filler parts.
  18. Resolved a "Left/Right Reveal Gap" issue in Door/Drawer cabinets. Drawer Fronts will now remain in alignment with doors when making minor adjustments to Left/Right reveals.
  19. Resolved a missing prompts issue in Base Open 2 Drawer. "Reveal" and "Gap" prompts are no longer hidden.
  20. Resolved an issue with the Strip Lighting Insert subassembly that caused the pocket recess routing to locate incorrectly in a nest.
To download this build, visit the Foundation Library Downloads Page.
