The following release notes apply to Microvellum Foundation Library, Build 24.0823
Additions
- Added a new global variable option, “Rebate With Router And Saw”. Selecting this option will enable two machine tokens per cabinet back edge as it associates to cabinet sides, tops, bottoms (Thick Back not supported). This option can be used when routing & sawing code is required for multiple machines (P2P & Nest). This can be set up with multiple processing stations and disabled G-code, as required per Toolfile.
- Added the “WallOffset” prompt to Filler and End Panel products to assist when they are associated to a wall.
- Added the ability to reverse or "flip" the machine point for fixed shelves in the Vertical Splitter subassembly.
- Added new material pointer “Shadow_Line_Solid_Rail_Material” and linked to all “Shadow Line Solid Material” prompts in all products. This will allow users to setup a contrasting color without changing the drawer front pointer. The Door Wizard "D!LookUpTableShadowline" column 7 lookup table has been updated.
- Added MDF Door edge pointers and linked them to the profile door subassembly:
- "Base_MDF_Door_Edge"
- "Tall_MDF_Door_Edge"
- "Upper_MDF_Door_Edge"
- "MDF_Drawer_Front_Edge"
- Added a new Door Style for the MV Profile Door called “Default Custom”. With this selected, the door variables are controlled with the below new door wizard variables instead of the LookUpTable.*
- Default Patten
- Default Rail Width
- Groove Panel Face
- Default Groove Spacing
- Default Groove Depth
- Split Drawer Rails
- Add Rail Lines
- Added a new option to Frameless Blind Corner Cabinets called “Rebated Blind Corner Panel” to notch into the top and bottom of the cabinet.
- Added the global variable “Floor Scribe” to all toe kick products and subassemblies.
- Added a feature to the Master Split Cabinet that enables the finished end(s) to be one piece or split like the rest of the cabinet.
- Added additional Sink brand options to better demonstrate how to add specific sink brands and models:
- Kohler 3839-1
- Kohler 3840-1
- Kraus KWT310-33
- Kraus KHU640-33
- Estilo EST0265
- Ausitn & Co AC15003
- Added a new cabinet face option, “Fixed Panel”, facilitated with the Component Doors subassembly. Several hardware items have been added and are available for this new option. They are duplicates of existing hardware added in the 24.0607 update, required due to differences with their associative machine tokens:
- Keku EH Suspension Fitting Left Fixed Panel
- Keku EHS Suspension Fitting Right Fixed Panel
- Keku EH Suspension Fitting Right Fixed Panel
- Keku EHS Suspension Fitting Left Fixed Panel
- SH 325 Zero Side Mount Fixed Panel
- Keku AS Push-In Fitting Fixed Panel
- Button Fix Type 2 Fixed Panel
- Added functionality to the Divisions With Fixed Shelves subassembly to control the construction holes for both the left and right holes.
- Added two Global Variables to better control the wood drawer default construction after library updates:
- "G!Default_Construction_Method_Wood_Drawers_Into_Bottom"
- "G!Default_Construction_Method_Wood_Drawers_Bottom"
- In Base 2 Door 2 Drawer, to eliminate face 6 machining, prompt values were added to the drawer subassemblies so that when there is a double top drawer with a single division, the drilling from the left drawer will drill through the drawer division on the left and the drilling from the right drawer will turn off on the left side.
- All Division subassemblies have had the "Reverse Machining Division 1" and "Reverse Machining Division 2" prompts added. These prompts allow the user to change the face for the machining of dados, cams, etc., and can be useful in preventing face 5 & 6 machining.
- Added extra hinges for lift-up and drop-down door conditions. One can now have up to 4 hinges.
- Added a new global variable, “Include Rear Dado On Divisions”, and updated all subassemblies using divisions. Select this option to add a rear dado on the back edge of the divisions, allowing them to securely slot into the cabinet thick back. This option is designed to work in conjunction with "Default Construction Method Rear".
- Added the TIP-ON BLUMOTION hardware to the Blum Legrabox:
- Blum Tip-On Blumotion set for LEGRABOX and MOVENTO
- Blum Tip-On Blumotion Synchronisation Linkage
- Added Blum Thin Door Hinges:
- Hinge BLUM Thin Door 110deg Full Overlay EXPANDO T@41mm
- Hinge BLUM Thin Door 110deg Half Overlay EXPANDO T@34mm
- Hinge BLUM Thin Door 110deg Inset EXPANDO T@25mm
- Added two new global variables to better control flatshot tokens. Clients can now globally control which parts to exclude and whether or not to include the labels.
- "Flatshot View Labels"
- "Flatshot Parts Filter"
- Added a new global variable, “Dado_Stretcher_Front_Notch_Distance_To_Edge” to control the front notch distance on all stretchers. This was added because, in many cases, the front notch needs to have a minimum width to avoid interference with the knives on an edgebander. We have also updated all rails to look at the global “Dado_Minimum_Width”.
- Added Folding Doors option to blind corner cabinets.
- Added additional sizes for Grass Nova Pro Scala drawer system.
- Added the Hawa Concepta III Pocket Door. This can be used as a stand-alone product located in the Master Cabinet Accessories or can be used as a Component Insert subassembly which can be added to any product. This product is considered to be in beta, still being developed and tested. Please submit any feedback to Microvellum by creating a support case.
- Added the Blum REVEGO Pocket Doors product. This is a stand-alone product located in the Master Cabinet Accessories. This product is considered to be in beta, still being developed and tested. Please submit any feedback to Microvellum by creating a support case.
Resolutions General
- Resolved an issue with 2D elevation of upper cabinets with wall fillers that were incorrectly moving with Bottom Reveal changes.
- Resolved an issue with Tall Fridge Cabinet. The Applied Ends will no longer move when the Bottom Reveal prompt is changed.
- Resolved an issue with Extruded Die Walls when using multiple skins and using the custom calculator to change sizes.
- Hafele Alto Slim drawer system will now have front molding parts for the inner drawer option.
- For all drawer systems, the “Back Grain Direction” and “Bottom Grain Direction” subassembly variables will now control these parts.
- Resolved an issue with Dowel & Screw machining. Holes on stretchers from divisions will only be face 5.
- When using Dado & Screw construction with regular dados, the drilling from the thick backs into the top and bottom is now on the correct side keeping all the machining on face 5. Also, the drilling and Rail Notch machining into the top stretcher will remain on face 5.
- In the Base 2 Door 2 Drawer product, the prompt “Double Division” has been renamed to “Double Drawer Division” to prevent a conflict with turning on a double horizontal division.
- When using the global “Drill Through at Divisions for Adj Shelves”, the routing machining for Lock Dados will now be on face 5 with the drilling.
- Resolved issue when “G!Dado_Depth_Thick_Back” is a different value than “G!Dado_Depth”. Thick backs will now be correctly sized.
- Resolved an issue that occurred with multiple drawer systems, wherein adjusting the "Bottom Gap" subassembly variable moved the runner holes in Z twice the needed distance.
- Resolved a drilling location issue with DTC Dragon Pro drawer system.
- Resolved a number of issues with the Diagonal Angle Cabinets which have been refactored and rebuilt. Corrected 2D elevation view.
- Resolved an issue with “Internal Drawers With Faces” Component Insert that prevented the divisions from appearing.
- Resolved an issue with Drawer Front Edgebanding, wherein a different color than the door's edging was needed. The “Finish_Face_Drawer_Edge” prompt has been added to all relevant products.
- Resolved a cabinet back router machining error that occurred from backs added via the Cabinet Modification options.
- Resolved numerous unspecified issues with various drawer systems as reported by users.
- Resolved an issue with the new Hafele Symo Lock not appearing in the list for users running the library update.
- For the Base Applied Back Panel product & all Applied End Panels, the "Grain Direction" prompt is now linked to the Finished Face panel.
- Added missing prompt data for the “Mirrored Value” across many Left/Right product prompts. This will help make the “Mirror Products” Toolbox feature much more reliable.
- Updated the global help image for “Front Shelf Hole to Edge”.
- Resolved issues that affected many products when using the Microvellum “Replace Product” feature. This function should now perform correctly.
- The Vertical Opening Splitter FF and Horizontal Opening Splitter FF subassemblies have been integrated into the Face Frame Vertical and Horizontal Designer Cabinets as Bay Face Options. The below products have been updated:
- Master Horizontal Designer Cabinet FF
- Master Vertical Designer Cabinet FF
- Master Upper Split Height Designer Cabinet FF
- Master Split Vertical Designer Cabinet FF
- Master Multi Carcase Designer Cabinet FF
- Added the Master Split Vertical Designer Cabinet FF product. This has the ability to split the carcass into two at any bay.
- Added the Split Height Face Frame & Upper Split Height Face Frame products to the Face Frame Only category.
- Added new global variable “Drawer_Front_Overlay_Middle” and pointed the product prompt "Drawer Front Middle Overlay" to the 2 Door 2 Drawer FF Cabinet.
- Updated the Leg Levelers in the Master Multi Carcase Designer Cabinet FF. Each carcase will now have its own set of leg levelers.
- Resolved an issue with Master Multi Carcase Designer Cabinet FF that caused the "Frame Overlay" prompts to be incorrect when Left and Right were different.
- Resolved a number of issues with the Face Frame Diagonal Angle Cabinets which have been refactored and rebuilt. Corrected 2D elevation view.
- Resolved an issue with Face Frame Corner Cabinets when product width was different than the product depth. Face Frame parts will now size correctly.
- Resolved an issue with Master Vertical Designer Cabinet FF, which occurred when using Division Inserts in the bottom bay and there is no cabinet bottom. Divisions will now have the correct size and position.
Additions/Resolutions Closet/Wardrobe Expansion
- Resolved issue with drawer depths hitting the rear inside cleats of closet products and not respecting the global “Back Space Requirement” variable.
